10-26-2010, 04:02 PM
Plexiglass bits?
I'm only a few days away from tackling my canopy - where are you guys finding the special plexiglass drillbits for use on the canopy?
10-26-2010, 07:43 PM
don't bother
I used plexi bits and still got cracks. Later, I was advised by one of the gurus on this site to simply to further dull a used #30 bit by drilling it into cement for a few bursts. I did just that and it worked well on the canopy.
Don Hall
N517DG - RV7 - Flying!
Ticked Van's Hobbes meter at #6110, 3/7/09
10-26-2010, 08:37 PM
Fastenal is where I picked up mine.
It has a reallly sharp point and worked well.
10-27-2010, 01:39 AM
...and a Unibit...
...in a slow cordless drill will work well to make small holes larger - but not for that initial hole.
I too drilled with a used #40 drill bit and had no trouble even in cool temperatures.
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
10-27-2010, 03:58 AM
I've had good success with simply reversing the drill and using standard (not too sharp) bits. It simply melts its way through without any grabbing at all.
10-27-2010, 05:51 AM
Glue the blimin thing with sikaflex and save your fears of cracking for something else...
Seriously I bolted on the outriggers of my 9 tonne steel trimaran and used sikaflex just to seal the plates. When I came to unbolt them years later I had to jump up and down, prise with bars and all kinds of things before the sika gave way. Sika is **** strong, flexible and UV resistant and probably a bit quicker too...
10-27-2010, 10:19 AM
TAP Plastics has several outlets here in the Northwest which several different sizes of plastic drill bits. Much cheaper than the aviation tool stores and of high quality. I've got a few sizes and have been impressed thus far.
________
Trevor Conroy CFII, MEI
Airbus Pilot
N781TD
RV-7
First Flight - April 12, 2015
Construction Log
10-27-2010, 10:34 AM
I bought the plexibits from averys....zero problems...and saved a few hundred over buying sika stuff.
Ryan Allen, CFII
RV7 N612RA, flying since july 2012
E-170/175
RV10 Tail Kit complete, Wings 90%, fuse on order
Acro Sport 2, building
10-27-2010, 11:08 AM
Plexiglass Bits
Buy your bits from Avery. He has quality tools. Be sure to have the Canopy very warm before you start drilling, I put a Ceramic
heater inside and brought the temperature up to about a 100 degrees and did not have any problems or cracks. The canopy temperature can not be too hot. If it is chilled you will have a good chance of cracks.
Dave Grosch / Portland, OR. / RV6A, Flying/Sold Labor Day 2013 after 10 years great flying. Previous owned airplanes, C-172 and a C-182. Total flying time, 30 years. Had a great run.
