Old 10-25-2010, 05:46 PM
Veetail88's Avatar
Veetail88 Veetail88 is offline
Default Wing tip screw count
I need a quick help.
I'm away from my project for a few days and I'd like to get an order out for nutplates for my wing tips.
Can someone get me a count?
Those little buggers are expensive and I don't want to buy twice as many as I'll need.
Thanks in advance
Jesse Bentley
N229Z - RV-8 - Flying - Livin' the dream!
Old 10-25-2010, 05:59 PM
chepburn's Avatar
chepburn chepburn is offline
Hi Jesse.
I've got 38 (per wing)
Chris
Thanks in advance
Chris Hepburn
Ottawa, ON
RV-8 C-GOGO FLYING
Renew 12/20
Old 10-25-2010, 07:49 PM
Veetail88's Avatar
Default Thanks Chris
I'll order them now and I'll have em for the weekend.
Jesse Bentley
Old 10-26-2010, 10:23 AM
LarryT LarryT is offline
Default Like nuts, bolts and screws
Thanks in advance
IMHO the shipping, handling, ordering hassle and delivery time has bitten me where I sit down. I now consider nutplates consumable items. Perhaps you might consider having extra nut plates on hand so you don't have to learn the hard way like me.
Also, Phillips head screws, especially SS, are particularly vulnerable and have finite life expectancy (think: one cam-out and they are junk). I think Pierre Smith, a frequent and knowledgeable contributor to this forum has changed his aircraft to internal torx-head screws.
LarryT
Old 10-26-2010, 10:31 AM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
I gave up on stainless screws (phillips head) for just about everything in my plane.
Here is a little tip to make screws last a lot longer.
Go to the local hardware store, and get a wax ring for a toilet. Be sure it is one made with beeswax. Use a toothpick or other small thingie to put a small dab of beeswax into each nutplate, before you insert the screw.
The difference it makes will amaze you.
By the way, the 10 uses close to 90 screws for the two wing tips, as I recall.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 10-26-2010, 10:44 AM
SHIPCHIEF SHIPCHIEF is offline
I pre-lube the screws that go into nutplates with antisieze compound. I just touch the threaded end of the screw against the antisieze brush, hardly any at all. Stripped philips heads are reduced.
I've read that other builders have run a tap into each platenut, but that sounds like a lot of time and work. The wax (or Boelube) or antisieze works for me.
I just bought a bunch of K1000-06 for the wingtips, $.51 ea! $38.76!! Although I think pop rivets are OK, The wingtips have a lot of 'stuff' in them these days: position lights, strobes, antennae, maybe the landing light, remote compass, someone put the auto pilot servo in the tip too.
Scott Emery
http://gallery.eaa326.org/v/members/semery/
EAA 668340, chapter 326 & IAC chapter 67
RV-8 N89SE first flight 12/26/2013
Yak55M, and the wife has an RV-4
There is nothing-absolute nothing-half so much worth doing as simply messing around with Aeroplanes
(with apologies to Ratty)
2019
Old 10-26-2010, 12:26 PM
frankh's Avatar
frankh frankh is offline
Default I vote for the torx
I used SS torx screws on every faster on the outside of the airplane (yes including the tanks) and I've never regretted that decision.
Have (so far) pulled +5 and -2.6G during an inverted spin (probably not with full tanks)..
The SS screws are just fine..
frank
Old 10-26-2010, 03:51 PM
Jamie Aust's Avatar
Jamie Aust Jamie Aust is offline
Thanks in advance
I just did this on my 7, its 38 a tip, grab a few extra while you are at it. I used #6 size screw, normal Cad.
Jamie lee
Brisbane, Australia
RV7A - Now Flying.
0-360,carb,catto 3 blade.
VH-XJL
