Old 10-24-2010, 10:34 PM
WISC WISC is offline
Default paperwork required to build???
I am torn between buying or trying my hand at building. I have tried searching the threads but can?t find a precise checklist of required paperwork.
I know a maintenance log must be kept, what specifically must be logged?
Are there any other logs that must be kept?
What paperwork do I have to file with the FAA?
What if you buy some parts (wings, tail etc...) from other builders, any special paperwork required?
If I buy completed sections does this jeopardize my ability to claim I?m the builder?
If I buy a flying aircraft I assume I just need a bill of sale and to register the aircraft, am I missing anything?????
As you can tell I?m a novice so sorry if these are elementary questions.
Thanks for the advice.
Old 10-25-2010, 06:39 AM
turbo's Avatar
turbo turbo is offline
Talking
if you want to fly, buy. that is your first decision to make. good luck.
TURBO YES =VAF= Payed Jan2019
Ed D'Arcy
addicted pickle ball player
Old 10-25-2010, 07:06 AM
Auburntsts's Avatar
I know a maintenance log must be kept, what specifically must be logged? I assume you're actually referring to the builder's log and nothing specific is required. A general description of your activitiy and lots of pics help to show that you were in fact the builder.
None during the build.
Nothing for the build itself. You will need to submit the following forms to register your aircraft (copied from EAA):
  1. AC Form 8050-1 Aircraft Registration Application
    Not available online. Must request a blank form from your FSDO (Flight Standards District Office).
    To locate your FSDO
    http://www.faa.gov/about/office_org/field_offices/
  2. AC Form 8050-2 Aircraft Bill of Sale (Kit built aircraft only)
    http://forms.faa.gov/forms/ac8050-2.pdf
  3. AC Form 8050-88 Affidavit of Ownership for Amateur Built Aircraft
    http://www.faa.gov/licenses_certificates/aircraft_certification/aircraft_registry/media/8050-88.pdf
  4. will need to submit the following to certificate your aircraft:
  5. AC Form 8130-6 Application for Airworthiness Certificate
    http://forms.faa.gov/forms/faa8130-6.pdf
  6. Enough data, such as photographs or three-view drawings, to identify the aircraft
  7. AC Form 8130-12 Eligibility Statement Amateur-Built Aircraft
    http://forms.faa.gov/forms/faa8130-12.pdf
  8. A letter identifying the aircraft and the area over which the aircraft will be tested
    Link to blank program letter
    Link to sample program letter
Not really, but you'll want a copy of their builder's log and probably want to contact Van's and let them know you are now the builder
If I buy completed sections does this jeopardize my ability to claim I’m the builder?
Possibly. This is why you want a copy of their log to show 51% compliance. If you have that then you shouldn't have an issue, at least with obtaining the airworthiness cert. However, depending on how much is already complete my jeopardize you're abilty to get the repairman's cert.
Can't help you here.
PP ASEL-IA
RV-10 N728TT - Flying!
WAR EAGLE!
Old 10-25-2010, 07:46 AM
MauiLvrs's Avatar
MauiLvrs MauiLvrs is offline
Buy the $20 packet from EAA.
Has the paperwork, instructions, checklist, labels.....
Dave & Trina
RV-9A Flying - 330 Hrs. Painted Finishing the interior.
Old 10-25-2010, 07:51 AM
Jamie's Avatar
Jamie Jamie is offline
Guys, I think he is asking what paperwork is required to build...and the answer is...NONE. Don't worry about paperwork until you're a few months from completion. You only need paperwork to register the airplane and to be granted an experimental airworthiness certificate.
Old 10-25-2010, 09:47 AM
N941WR's Avatar
N941WR N941WR is offline
Jamie is correct. However, during your build, you will want to track your build hours and take pictures of YOURSELF building the plane as proof you are the person who built it.
For my builder's log, I simply used Excel and linked pictures to each task. Simple and easy.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 10-25-2010, 09:55 AM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
Only paperwork needed to build is a fat checkbook
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 10-25-2010, 10:00 AM
Dave Taylor's Avatar
Dave Taylor Dave Taylor is offline
Default Paperwork
If you buy a project from another builder you will need to transfer the project from the builder to you and send the paperwork to Van's
David Taylor
RV-7 N207DT
Wings
Warner Robins, GA
"The greatest mistake you can make in life is to be continually fearing you will make one. "
Elbert Hubbard
Old 10-25-2010, 02:43 PM
papamike's Avatar
papamike papamike is offline
Default Ditto...
Ditto the above from Dave. I bought my tail kit from another builder. We typed up and signed a bill of sale. Just call Van's; they will talk you through it and send you the necessary paperwork for that part of it.
Pete Miller
RV-7 Panel and Avionics
N174PM (reserved)
McKinney, TX (T31)
http://smilinpete.com
Old 10-25-2010, 03:04 PM
You guys rock!!! Thanks!!!
