Old 10-24-2010, 05:44 PM
ron sterba ron sterba is offline
Red face 9A QB Instrument panel with DYNON 10"
I just started my panel with the Ribs F7108 A. I was just told that I may have to cut the ribs to the firewll for the Dynon Skyview 10" and redesign that portion. Has anybody done that or willl the Dynon fit with the VANS factory drawing board design. If you have pictures that would be GREAT!
Thanks RON.
Old 10-24-2010, 05:52 PM
airguy's Avatar
airguy airguy is offline
Hmm - interested to see the replies here, since I'll probably be cutting those same ribs TOMORROW.
Old 10-24-2010, 09:01 PM
Jeff R's Avatar
Jeff R Jeff R is offline
I am just doing some trial fitting of my panel with a dual Dynon 10" display and the ribs are not in the way. I will have to trim one rib in the radio stack area, as well as make a cutout for the radios in the subpanel, but the Dynon's are fine. Unless you mounted the Dynon's high up on the panel, I don't see how you would have a problem.
Jeff Rosson
Repeat Offender
RV14 - Working on Empennage/Tail Cone
RV9A - Completed! First flight on July 18, 2012!
Based at Merritt Island, FL (KCOI)
VAF Number: 1170
Star Trek Quote: "Logically, it could work. Also, logically, there are a hundred variables, any one of which could put us in a worse position than we're in now." Mr. Spock in Return to Tomorrow
Old 10-24-2010, 10:08 PM
petehowell's Avatar
Default Nice Panel
Russ - that is one great looking panel/interior!! You will love the 9A.
Pete
Amateur Radio - KD0CVN
Doggies Delivered - 25+
St. Paul, MN
Old 10-24-2010, 10:21 PM
russd's Avatar
russd russd is offline
Default 9A Panel
Thanks Pete, I can't wait! I thought I could delete the post before anybody saw my bif-up but it didn't work. I mis-read the part number and my reply wasn't for this thread.
-Russ
KGXY
RV-9A, Tip-up, Titan 320, Catto 3-blade, Flying!
Old 10-25-2010, 01:32 AM
KRviator's Avatar
KRviator KRviator is offline
Following on from this, what are the chances of fitting two 10" screens outboard of a 7" screen in the centre of the panel with a '430 below?
Once you have tasted flight you will forever walk the earth with your eyes turned skywards, for there you have been and there you will long to return - Leonardo DaVinci
My Flickr gallery: http://www.flickr.com/photos/35521362@N06/
RV-9A - Finished on 10th February 2016 after 4 years, 9 months and 19 days! The 1020th RV-9 flying.
First flight 26th March 2016. Essential specs 145KTAS @ 2400RPM, 8000', 24.2LPH, Initial RoC 1800FPM.
Old 10-25-2010, 03:27 PM
Hey Russ could you post your picture of your panel here. Thanks Ron in Oregon
Old 10-25-2010, 07:35 PM
russd's Avatar
Default Panel Pics
Sure Ron, but they're for a tip-up. That's why I deleted the post. I couldn't figure out a way to mount the 10" displays without removing and relocating the ribs. The canopy jetison stuff had to go too!
-Russ
KGXY
Old 10-26-2010, 12:38 AM
Thanks Russ, very nicely done my friend!!!! Ron in Oregon
Old 10-26-2010, 06:27 AM
flybye flybye is offline
Default Very nice looking panel Russ.
Very clean lines and symmetry. The VP-50 relieves the need for switches which can be a challenge in designing a layout. What are the switches you've used under the left hand EFIS?
RV9a
