This is just one man's version. First thing to do is set the baffle height using methods of your choice. The right corner is going to determine how how high you can set the cooler up. Where the bottom goes is just where it ends up but it should be well above the bottom of the baffle. See pix below.
Keeping it from shaking is also important. I ran a 3/8 SS tube flattened on both ends and bent accordingly to brace the rear baffle. It comes off the engine block to the baffle and note that I also reinforced the area it goes to as well.
Uploaded with
ImageShack.us
The following may be overkill :-( On the back side, I put a .032 plate over the whole cooler area and extends around the engine mount and ties into the lower block baffle bolt. Can send pictures by Em if you want them.
Uploaded with
ImageShack.us
Uploaded with
ImageShack.us
It is absolutly rock solid in all directions. I also paid close attention to the blot spacers so that there was NO clamping distortion when they were tightened up. I also used larger washers on that side to spread the stress area. I "think" I also used sligthly larger washers under the flange as well and fit them with a grinder. Note area cut out to clear mount. I repositioned another bolt so that I still have 3 on that side.
Uploaded with
ImageShack.us
Not sure this won't move a stress crack someplace else but it's just what I did. Don't have enough hours to tell if it will work long term but for now it looks good.
Hope the pictures help!
Bill S
7a on the verge
