I'm in a bit of a quandry here and I need some help from some engine experts out there.
Engine details: IO-320-B1A, S/N RL-1083-55B (Bravo, not 8)
Below is a picture of my engine during disassembly.
The thing is I was pretty sure I have a "narrow" deck engine based on the
http://www.sacskyranch.com/lycoming.htm. My cylinders use the hold down plates and the internal hex style hold-down barrel nuts. Lastly, my engine S/N doesn't end in "A" which is supposed to be for wide deck.
However, now that the engine is all apart and I've sent the case off to Divco to be inspected and overhauled if needed. Divco offered to just swap me a case. They indicate that I have a wide deck case?!?!?!
So now I'm really confused, I didn't think you could mount narrow deck cylinders on a wide deck case. Is it possible that I'm missing something else? I have the engine log book and it was a factory reman from Lycoming in 1978, and I know they changed from narrow to wide between 1960 and 1970.
I'd appreciate any advice you can give me. TIA
