Old 10-22-2010, 07:26 AM
gordodavis gordodavis is offline
Default Purchasing Adel Clamps
Getting ready to purchase an assortment of adel clamps, any particular size I should really load up on?
Old 10-22-2010, 08:07 AM
apkp777's Avatar
apkp777 apkp777 is offline
The engine mount uses -14 and -16. I'd get at least 10 of each.
Tony Phillips
N524AP, RV 9 (tail wheel)
Old 10-22-2010, 08:18 AM
schristo@mac.com's Avatar
schristo@mac.com schristo@mac.com is offline
Default Adel clamps
You will find use for everything from 3 through 8, a few 10s and a bunch of 12s for the engine mount... suggest that you get wedge type clamps for any hard tube application like the mount. I also used a 24 on a piece of sceet hose and I recall using several 14s on one of the engine mount tubes.
I probably picked up adel clamps half a dozen times with other orders during the build.
I found that the all metal lock nuts were much easier to deal with when manipulating a clamp closed, especially with double clamp situations.
Stephen
RV7 powered by a lycoming thunderbolt IO-390
turning a whirlwind HRT prop
with more hours flying than building... 2,430 on the hobbs!
ORCA Flight
Race 771
margarita!
Old 10-22-2010, 08:32 AM
N941WR's Avatar
N941WR N941WR is offline
Add to that -4, -6, -8, -10, & -12's. I've also got some -9 & -11's. As my wire bundles grew, so did my need for larger clamps. Buy a bunch of each. There is nothing so aggravating as being one short.
Here's a picture of how and why I used so many different sizes:
One tip, I always wrap my engine mount with one layer of black electrical tape before installing the clamp. This helps keep them from turning on the mount.
Does anyone know what size fits over the intake tubes? I'm using high temp zip-ties to secure the CHT wires but would really like to use Adel clamps.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 10-23-2010, 06:22 AM
Default Thanks
Thanks everyone, this info helps.
Old 10-23-2010, 10:04 AM
Bob'sRV6A Bob'sRV6A is offline
Default I forgot
to order the screws in my initial Adel Clamp purchase--from Spruce by the way. The seemed a little cheaper. Do I need just one size screw and nut? All the same length?
Bob
Old 10-23-2010, 11:12 AM
N941WR's Avatar
Bob
You will want to get some AN525-10 Washer Head screws. The length will depend on how many clamps you are putting together. AN960-10 washers (Get some "L" sized ones while you are at it.) will be needed along with some MS21042-3 (10-32) stop nuts to go along with the screws and washers.
Buy a bunch of these as you will use them all over the place.
Bill R.
SC86 - Easley, SC
