Old 10-21-2010, 06:13 PM
papamike's Avatar
papamike papamike is offline
Default Carbon Fiber panel step-by-step?
I remember seeing a website where the builder described in detail how he built a carbon-fiber panel for an RV, but I can't find it anymore. The site had pictures of everything including the plywood forms and the bagging process. Anybody have any idea where I can find this site? I need to get better at saving sites where I find items of interest.
Pete Miller
RV-7 Panel and Avionics
N174PM (reserved)
McKinney, TX (T31)
http://smilinpete.com
Old 10-21-2010, 06:20 PM
jferraro17's Avatar
jferraro17 jferraro17 is offline
Opulence, I has it...
http://www.jeffsrv-7a.com/PANEL.htm
Joe Ferraro
DFW, VAF #17
SOLD
Old 10-21-2010, 09:48 PM
float208 float208 is offline
Default CF panel
The easiest way is to use a piece of glass, lay up 2 layers of Carbon fiber cloth on it using lots of resin and working out ALL the bubbles. The glass surface will be the face of the panel. This is also handy as you can flip it over and see the bubbles if there are any. Let it set up a bit and place a couple layers of E-glass on the CF to add strength. Add whatever you need to built to your needs, Do you want the panel to be "The Panel" in which case you will need some extra thickness, and strength, or just use it to cover the metal panel underneath in which case it can be relativly thin??? When it has cured, simply peel it off the glass carfully. You should have a very smooth surface!!! However I usually sand it with 1000, 1500, and then add several layers of Clear. If you let them dry, resand with 1500 and repeat until you have the desired appearence. For the best result sand with 2500 and buff to a glass smooth surface. This will also protect the epoxy from UV rays which break down the resin. Cut out your holes for instruments etc.. just like you would a metal panel.
Old 10-21-2010, 10:58 PM
RV7Guy's Avatar
RV7Guy RV7Guy is offline
Default Carbon
I have a carbon fiber panel. It is an overlay of the stock panel. It is two layers of 8 oz glass cloth then two layers of carbon at a 45 degree angle. The lay up was vacuum bagged. The blank was fastened to the stock panel then cut to shape.
It looks great.
Darwin N. Barrie
Chandler AZ
www.JDair.com
RV-7 N717EE-Flying (Sold)
RV-7 N717AZ Flying, in paint
EMS Bell 407,
Eurocopter 350 A-Star Driver
Old 10-22-2010, 07:43 AM
yakdriver yakdriver is offline
Or do it the easy way. www.dragonplate.com has carbon fiber sheets with 3M adhesive. This is real carbon fiber and it looks great. It will bend around a small radius with a heat gun. I'm a compyter zero or I would post the pictures of mine. Don
RV 7 N212MD Flying as of 12/22/2007
Backcountry/TCOW Super Cub flying 03/12/2011
Next project?
Old 10-22-2010, 07:57 AM
papamike's Avatar
Default Thanks
Thanks guys. I'm not there yet, but I wanted to save that information for when I do need it. I also just got out of a composite class at work and it's been on the brain all week.
Pete Miller
N174PM (reserved)
McKinney, TX (T31)
Old 10-22-2010, 08:00 AM
Bushcaddy Bushcaddy is offline
Default Here's what the overlay looks like...
I did the overlay, real easy and it looks great:
http://webhosting.web.com/imagelib/s...g&target=_self
I did not get the 3M adhesive, just secured it in a few strategic areas with 8/32 screws and nutplates. I got a 1.5 MM sheet here:
http://www.robotmarketplace.com/prod...ials_main.html
Don...
Plymouth, MA
Varga 2180; N2C
http://www.n2charlie.com
2013 Donation Made
Old 10-22-2010, 08:04 AM
Bullseye's Avatar
Bullseye Bullseye is offline
I looked around dragonplate a little.
They have a ton of products, but the ones that were mentioned were the:
Twill weave verneer: http://www.dragonplate.com/ecart/categories.asp?cID=78
Plain weave verneer: http://www.dragonplate.com/ecart/categories.asp?cID=77
Instead of just a covering, you could probably go with one of the thicker sheets of the carbon fiber sheets: http://www.dragonplate.com/ecart/categories.asp?cID=65
Andrew Z.
Engineering Flight Test Pilot/Engineer, CFI-A, CFII, ATP
RV-7 in work (See my build log.)
Empennage...Done (except rebuilding the rudder.)
Wings...Halfway complete.
2018 Dues Paid
Old 10-25-2010, 08:07 PM
David Shelton's Avatar
David Shelton David Shelton is offline
Default A few tips
Here is the technique I used to skin my neighbors aluminum panel:
1) Lightly sand, then acid etch the aluminum parts to ensure a good bond.
2) Spray your parts with a thin coat of black epoxy primer or gel coat. This will prevent any aluminum from showing through the cloths weave. Alternative: Use two layers of carbon fiber cloth... but this is more expensive.
3) After the gel coat is tacky to the touch, lay your carbon fiber cloth into position. It should wrap around corners and stick to the tacky surface.
4) Impregnate the cloth with resin, working all the air bubbles out. A hair dryer is sometimes useful for chasing air bubbles out.
5) After the first layer of resin is tacky, gently brush on another thick layer. Repeat this several times, building up a very thick layer of resin.
6) After a complete cure, block sand your parts smooth. You need to sand enough to level the surface and not enough to reach the carbon cloth.
7) Wet sand up to 1,000 grit, then polish.
This was a plain weave cloth, but I personally prefer the look of a twill weave. I believe I used MGS 335 resin.
http://s807.photobucket.com/albums/y...=IMG_5454b.jpg
http://s807.photobucket.com/albums/y...=IMG_5451b.jpg
David Shelton, Aerospace Engineer and Soaring Nut.
