Old 10-20-2010, 03:17 PM
pierre smith's Avatar
Default Garmin 1000 question.
I just gave a BFR to a gent in a 4 place Katana with two G-1000 units and a Garmin autopilot. We were discussing his upcoming IFR training and I didn't know whether or not the 1000 was capable of flying coupled ILS approaches...do they?
Pierre Smith
RV-10, 510 TT
Air Tractor 402 PT-6-20 Sold
Louisville, Ga
Patrick Kenny, EAA 275132
Dues gladly paid!
Old 10-20-2010, 03:32 PM
PH-SCP PH-SCP is offline
A four place Katana would make it a Diamond DA-40 Star....
We have two at our local FBO (and a twin engined four place Katana which is a DA-42 Twin Star), all of which are G1000 equipped and all of which fly coupled approaches very nicely..
There are some things to consider when you give the student/candidate a system failure. These units combine a large number of functions and killing a screen could very well turn off your radio's and/or transponder.
You may want to go through the POH very carefully before hopping into the Star and scare ATC with your transponder disappearing and no longer answering to calls... Please don't ask me how I know...
Good luck !
Simon C. Paul
Maastricht Airport (EHBK/MST)
The Netherlands
RV-9
PH-SCP
"Building an aircraft is the male equivalent to giving birth, it only involves more blood and pain "
Phil's Avatar
Phil Phil is offline
Default Yep
I fly one that is coupled to a King AP.
I'm sure it depends on the AP-type, but in the plane I fly it will do it.
Phil
Old 10-20-2010, 05:15 PM
SteinAir SteinAir is offline
It depends on the age of that plane and which particular system(s) are installed. Some are WAAS and some are not. It also depends on the A/P....
Anyway, I couldn't give you a definitive answer without knowing the details of the equipment, but properly equipped you can fly (coupled up) pretty much every approach known - both analog and/or digital. Did the unit you fly behind have SVT and the velocity vector/pip on it?
Stein
Old 10-20-2010, 06:37 PM
scard's Avatar
scard scard is offline
The one I had a bunch of time in, with a G1000/King a/p, would do ok with a fully coupled ILS approach. But nowhere near as nice as the RV .
Scott Card
CMW E-Lift
Old 10-20-2010, 08:33 PM
KatieB's Avatar
KatieB KatieB is offline
Default Nice plane!
Yep, we had some of the first G1000-equipped DA-40 Diamond Stars at my old flight school with King autopilots and they flew coupled ILSs. Very nice airplanes. I'd like to fly one with an integrated Garmin autopilot sometime.
Another thing to consider-- Garmin may have "fixed" this since then, but we found out the hard way that you shouldn't pull circuit breakers to kill different elements of the system in flight. We went through magnetometers at an alarming rate. Garmin said those things should outlast the airplane, and eventually figured out that pulling breakers screwed them up. We had to dim the screens to simulate partial-panel.
Katie Bosman
RV-3B sold, but flying!
Next project: ???
Builders gonna build...
Old 10-21-2010, 05:04 AM
Default Say what??
Originally Posted by SteinAir View Post
......... Did the unit you fly behind have SVT and the velocity vector/pip on it?
Stein
What's a velocity vector pip? It had two magenta colored pointers on the AH screen pointing inwards, if that's what you're referring to. No synthetic vision.
Thanks everybody,
Pierre Smith
RV-10, 510 TT
Louisville, Ga
Dues gladly paid!
Old 10-21-2010, 05:32 AM
mburch's Avatar
mburch mburch is offline
The V-shaped magenta things are the flight director command bars. Here's a cockpit reference guide that might help: http://static.garmincdn.com/pumac/G1...renceGuide.pdf
mcb
Matt Burch
RV-7 (last 90%)
http://www.rv7blog.com
VAF #836
Any opinions expressed in this message are my own and not those of my employer.
Old 10-21-2010, 09:21 AM
DGlaeser DGlaeser is offline
Default G1000 Velocity Vector
Thanks everybody,
The velocity vector is shown on the MFD Map. It is a teal line that shows where you will be in a configurable number of minutes. If you keep the teal line on the magenta line, you have the perfect heading to maintain your course. Very useful.
The magenta triangles on the PFD (horizontally long, vertically short) are the Flight Director command bars.
The Cessnas I instruct in (172s, 182, 350) are all G1000 and we have a mix of the KAP140 and GFC700 autopilots. They not only fly coupled approaches, but on the miss, will go out and do the holding for you as well
The GFC700 has a vertical mode (FLC - flight level change) which maintains an airspeed instead of vertical speed - much safer for climbs. It also will follow the vertical track mode, if used, for descents.
Dennis Glaeser CFII
Rochester Hills, MI
RV-7A - Eggenfellner H6, GRT Sport ES, EIS4000, 300XL, SL30, TT Gemini, PMA6000, AK950L, GT320,
uAvionixEcho ADSB in/out with GRT Safe Fly GPS
Old 10-21-2010, 09:40 AM
Plummit's Avatar
Plummit Plummit is offline
What do you mean by "Coupled"? If you are talking about the auto pilot which one? The G-1000 will fly coupled auto-pilot approaches with both the Kap 140 and the GFC 700. The GFC 700 has a couple more features but both do a nice job. If it has the WAAS gps then you can fly a WAAS approach, otherwise you are limited to ILS, VOR, LDA etc.
regards
~Marc
