  #11
Old 10-20-2010, 08:19 PM
guccidude1 guccidude1 is offline
Default Heated Pitot tube-remcomendations?
A little detour to provide added info on the thread, the Dynon Pitot can be used on the MGL EFIS systems, my buddy (RV-7A) has one installed. Dan
Old 11-11-2010, 03:19 PM
The Wizzard's Avatar
The Wizzard The Wizzard is offline
Default thanks for all the help
I think I am going to go with the gretz model. The mounting seems simple enough and can be used universally.
Old 11-29-2010, 01:07 PM
floydpackard floydpackard is offline
Just for reference. I have the Dynon heated pitot. I have had problems with it icing up in IMC 4 times. I have contaced Dynon and had it replaced once and it still ices up. It happens when I am up high and very cold and I don't think it is the tube that is icing up but that there is not an adequate water drain hole. It lets water get past the heated parts and then it freezes up in the wing. I am looking to replace it with a used cessna tube or perhaps a falcon.
Floyd
Floyd Packard
bought flying RV7a (Roberta's)
Kennewick WA
New pilot, learning and loving it!
Old 11-29-2010, 06:01 PM
Floyd, thanks for the intell, I think I am going to use the Gretz tube although the Falcon is a great one as well.
Old 11-30-2010, 06:26 AM
Joe Joe is offline
Floyd, are you using that heated pitot with a Dynon EFIS? If so, how did the EFIS perform when the pitot was iced up? Did it go into its "GPS assist" mode and if so, how was the attitude information? (Perhaps this was your first indication it was iced up.)
Joe
Joe Dubner
RV-8A
Independence, OR
Old 11-30-2010, 07:30 AM
Brantel's Avatar
Brantel Brantel is offline
I am asking this question not to be smart or to criticize. I am really curious if it is normal practice or not....Is it wise to fly an RV in the soup above the freezing level anyway? Seems that RV's are far from being capable of handling icing conditions so how does this impact their usability in IMC?
Brantel (Brian Chesteen),
RV-7/TU, #72823, N159SB
Track N159SB (KK4LIF)
Old 11-30-2010, 08:20 AM
bkthomps bkthomps is offline
could be descending through a thin layer, lots of ways he could have encountered this without being necessarily out of operating conditions
Old 11-30-2010, 10:17 AM
I fly with a GRT Hx. When the pitot gets plugged the efis continues to function without a problem. The indicated airspeed drops off and the efis starts to show greater and greater tail winds as the efis calculates the ground speed against the indicated airspeed. All other parts of the efis are unaffected.
When I go through IMC in sub zero conditions I keep a back door ie above freezing below and visual conditions below. I find that with the performance of the rv and good back doors you can get on top (as long as you know where the reported tops are). What ice is picked up sublimates off. It is not unusual for me to travel in the flight levels to stay above layers. I do not stay in the clouds but am always searching for layers and tops and change altitudes readily. If I begin to pick up ice my first move is usually up I do not stay in it.
I know flying in possible icing conditions is controversial. Some will not fly through any cloud that is below freezing level. Others will look for ways to mitigate risks. The question of the thread was about heated pitot tubes. I felt it would be benificial to have data points in actual conditions. I have lost indicated airspeed with no air frame icing at all just very cold with ice crystals in the air. Dynon is a very good company and they have been responsive to me in replacing the tube. I could be wrong but in my opinion there is still a design flaw that does not hold up to actual conditions. But then again perhaps no tube does all the time hence the dual tubes on commercial.
Also as another data point. TT VSGV loses vertical control with no or low indicated airspeed (as it should). The wing level still works
Hope this helps
Floyd
Floyd Packard
Kennewick WA
Old 11-30-2010, 06:37 PM
LifeofReiley's Avatar
LifeofReiley LifeofReiley is offline
Default well...
a little different here... the Piper Flat Blade, pitot heated and static in one. FWIW, I would not install a heated pilot if I did it over again, does nothing for me.
Reiley
Retired N622DR - Serial #V7A1467
VAF# 671
Repeat Offender / Race 007
Friend of the RV-1
Old 11-30-2010, 06:42 PM
scard's Avatar
scard scard is offline
Depends on the mission. I'm installing a heated pitot again. I have switched it on a handful of times and was glad it was there.
Scott Card
CMW E-Lift
