Old 10-18-2010, 09:00 PM
Jerry Cochran's Avatar
Jerry Cochran Jerry Cochran is offline
Default 8a to 8 conversion?
Anyone know what it takes to convert and 8a kit to 8 given that fuse has not been started? Obviously gear legs and need tail wheel... What else?
I know this has been done before...
Jerry Cochran
Sherwood, Oregon
RV-7a 707DD Bot from David Domeier 12/01/11
Lycoming IO-360 Catto 3 blade Panel upgrade in progress
RV6a 18XP 1st flite 03/21/07 sold to Dale Walter 10/22/2011
Superior IO-360, Hartzell Blended, GRT/Dynon
Happily "autopaying" DR
"Suppose you were an idiot, and suppose you were a member of Congress; but I repeat myself."
Mark Twain
Old 10-18-2010, 09:22 PM
Neal@F14's Avatar
Neal@F14 Neal@F14 is offline
Gear towers will have to be added into the fuselage. The -8A fuselage is absent these important structures. It's theoretically doable, but definitely not a trivial amount of work.
Here's a thread with more details: http://www.vansairforce.com/communit...ad.php?t=44555
Neal Howard
Airplaneless once again...
