Old 10-17-2010, 08:16 PM
BGordon's Avatar
BGordon BGordon is offline
Default Why only half the screws???
I am about ready to mount my tank and was wondering why the instructions say to install every other screw and only half the bolts in the Z brackets. I read ahead and can't figure why, and when the rest of the screws/bolts go in. Any ideas? would it be all right that if it tests airtight I just go ahead and mount it permanently?
thank you,
Brandon
Brandon Gordon
KFWS, Burleson, TX
Old 10-17-2010, 09:00 PM
sonny junell's Avatar
sonny junell sonny junell is offline
This is classic vans
"we like to p*ss the builder off, by making them do the same thing a minimum of two times"
Mounting the Horizontal Stabilizer was a total cluster. Then only to crescendo, in the instructions saying "now remove the horizontal for storage WTF!
Seriously though I have no clue why it would be necessary to remove . . Some one have a real answer?
Time, patience, and perseverance overcomes all obstacles.
Our Kit log
www.westernsheetmetal.com
Old 10-17-2010, 09:03 PM
kevinh's Avatar
kevinh kevinh is offline
It will be very likely to get hangar rash. Also, after the HS is mounted there is still a lot more to do. I'm sure I saved many times the time required to remove the HS in just the shorter walk around the back of the plane.
-kevinh, Track my RV-7A, flying, alas, sold in 2013 after 450ish hours. (I'm now building something different)
Old 10-18-2010, 09:01 AM
Dave Taylor's Avatar
Dave Taylor Dave Taylor is offline
Default Less work
My guess is they only have you put in the bolts for alignment to drill. You will have to pull the z channel brackets off to deburr.
David Taylor
RV-7 N207DT
Wings
Warner Robins, GA
"The greatest mistake you can make in life is to be continually fearing you will make one. "
Elbert Hubbard
