Old 10-17-2010, 05:00 PM
clucier clucier is offline
Default Section 07-03 Step 1 trial fit of the rudder Spar to the VS
Please take a look at this pick, have a gap in the upper bracket, the plan says to use only one washer between the bracket and the hinge on each side, doing so leaves a gap as big as the thick washer, bottom is perfect fit.
http://picasaweb.google.com/lh/photo...eat=directlink
The holes in the spar are pre-punched as are the brackets attached to the rudder spar.
? Should I add another washer? is this normal or do I have a bum part? If I tighten this it will pinch on the bolt, not something I think you want on a critical hinge point...
Chris Lucier
http://RV12SP.Blogspot.com
RV12 Empennage Arrived (Early)
N712EC Serial number 120424
President EAA Chapter 228
Old 10-17-2010, 05:14 PM
redmark redmark is offline
Chris,
My plans say to add washers IF/AS Required so add one more to fill the gap.
-Ron
Old 10-17-2010, 05:17 PM
Thats what I was thinking but above that it says
" and only one washer between each hinge bracket and upper hinge assembly"
Chris Lucier
Old 10-17-2010, 06:15 PM
joedallas's Avatar
joedallas joedallas is offline
I have one washer on the top and one on the bottom of the top hinge and only a small gap left about .007 to .009 thousands and the top of the spar lines up perfect with the top spar of the stabilizer and on the bottom hinge I have one L washer on the top and one reg and one L washer on the bottom.
And my hinge brackets are parallel I checked with a micrometer
The bearing is .281 the distance between the top brackets is .417 two washers about .127 = or - balance .009 = or -
The top hinge should work out fine the bottom may be a little off as this is a weldment.
Joe Dallas
Kit-#12400
www.joesrv12.com
www.EAA1298.com
Old 10-21-2010, 03:10 PM
WingedFrog's Avatar
WingedFrog WingedFrog is offline
I had the same gap, took note of it and postponed for a decision later. I just noted that the gap disappears when tightening the bolt. The instructions are specific about using one washer only each place and adjusting by choosing between regular or L washers. As there is nothing about not tightening to reduce the remaining gap, I thought it was OK. Am I wrong?
Builder's name: Jean-Pierre Bernoux
Sport Pilot
Kit # 120395 N124BX
Flying as of 9/11/2013
Builder's Blog:http://vieilleburette.blogspot.com/
EAA 1114
Old 10-19-2016, 11:41 AM
epaslick's Avatar
epaslick epaslick is offline
Question
Sorry to revive an old thread. I too have reached this step and have questions. The lower hinge (weldment) fits perfectly with one thick washer (NAS1149F0363P [AN960-10]) above and below. The upper hinge, however, fits with one thick washer below and one thick washer and one thin washer (NAS1149F0332P [AN960-10L]). There doesn't seem to be a consensus on adding a second washer or tightening the bolt to squeeze the rudder hinge closed. I would personally think it's better to shim it with the second washer but I would really like to hear the voices of experience first.
Eric Paslick
EAA Chapter 732
Siloam Springs, AR
Sonerai IIL N968KB Flying
RV-12 #120991
History's slowest RV-12 build
Empennage: In work
N62EP Reserved
2019 Donation Made
Old 10-19-2016, 05:54 PM
Mich48041 Mich48041 is offline
I had the exact same situation as Eric. I thought it best not to bend parts. So I used one thick and one thin washer on top of the top bearing.
Joe Gores
RV-12 Flying
