Old 10-16-2010, 10:27 AM
blahphish's Avatar
blahphish blahphish is offline
Default Is this 470 rivet ok?
I have a 'friend' who is new to building and he kind of messed up the head of one of the rivets. He wants to know if this is something thats ok to leave as is or does it need to be drilled out? Its the rivet in the top right that looks like its cloning itself.
... ok it was me
Brian Unrein
RV10 N42BU 900+ hours!
First flight 6-16-12
https://N42BU.com
Old 10-16-2010, 10:29 AM
Danny7 Danny7 is offline
remove and replace: the set has in effect cut a significant portion of the head
nothing special here...
ErichKeane ErichKeane is offline
Definitely need to be drilled out.
RV-12: 331RV
Started 3/31/10
First Flight: 4/2/11
Old 10-16-2010, 11:26 AM
blahphish's Avatar
will do. thanks guys.
Brian Unrein
https://N42BU.com
Old 10-16-2010, 01:38 PM
N427EF N427EF is offline
Brian,
Very funny, looks like 829GW just had a baby.......
Where on the 10 is that part located?
And yes, drill out that rivet and maybe a couple more.
Ernst Freitag
RV-8 finished (sold)
RV-10 Flyer 600 plus hours
Running on E10 mogas
Old 10-16-2010, 02:10 PM
blahphish's Avatar
The pic is of the spar web extension piece that attaches to the end of the wing spar. I have already drilled out the bad one and will take a second look at the other rivets pointed out. Thanks for all the good feedback everyone.
Brian Unrein
https://N42BU.com
Old 10-16-2010, 02:37 PM
Bill Dicus Bill Dicus is offline
Default Bad 470's
Key for me was to intently keep pressure on the rivet gun until it has completely stopped operating. Guard can help too. Keep on going!
Bill Dicus
Shorewood (Milwaukee) Wisconsin
RV-8 N9669D Flying 12/4/14!
Flying Pitts S-2A, Piper Lance
Old 10-17-2010, 06:53 PM
airguy's Avatar
airguy airguy is offline
You may find it helpful at first to operate the rivet gun in short bursts of 1/2 second or so - then review the position of both the gun and the bucking bar, get it all squared up, give it another 1/2 second squeeze, etc. This will prevent you from picking the gun up off the work (or allowing it to bounce up) before the trigger is released, which is exactly what causes the problems you're seeing there.
Just the same as you have to keep flying the airplane until it's completely stopped, you also have to keep paying attention to the rivet gun until it's completely quiet.
