10-15-2010, 02:45 PM
IO-360 Strange Start Problem
IO-360, high comp pistons, starts normally, then fumbles, runs rough, and #2 EGT is abnormally low; condition doesn't smooth out. Engine shutdown, wait a couple minutes and restart; and restart cures the problem - no further problems. Plugs have been cleaned (look good) and the fuel line to #2 has been removed, blown out clean --- same problem persists. Mystifying!
Any ideas?
Barney, in Memphis
RV-4 flying
RV-3 flying
10-15-2010, 03:41 PM
I'd be looking for a stuck valve.
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
10-15-2010, 04:11 PM
Potential induction leak. Something may be cracked and have a gap when it is cold, then the assembly heats up, grows due to the heat, and seals the gap.
Kyle Boatright
Marietta, GA
2001 RV-6 N46KB
2019(?) RV-10
10-15-2010, 08:00 PM
Walt,
Thanks for the heads up. I should have thought of s sticking valve myself. After reading the Lycoming Flyer, Key Operations -1 at: http://www.lycoming.com/support/tips...Operations.pdf I am even more suspicious of a sticking valve. I will so advise the owner of the aircraft of your advice.
Barney, in Memphis
RV-4 flying
RV-3 flying
10-24-2010, 02:54 PM
Stuck Exhaust Valve = Culprit
Engine has 4 into 1 exhaust: We pulled the prop through while listening with our best ear at the exhaust pipe. Three cylinders exhausted with a BIG POOF, and the culprit just hissssssed!
Barney, in Memphis
RV-3 flying
RV-4 flying
10-24-2010, 03:07 PM
Senior Curmudgeon
Rope trick time.......
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
10-24-2010, 07:29 PM
Sounds like a stuck valve.
Whats "the Rope Trick" Mike?
Regards
Luis  --------------------------- RV-10---------------------------  Empennage. Complete Minus fiberglass and attach section. FOR SALE
Build Log N925LC (Reserved) YouTube
10-24-2010, 07:56 PM
Morning Sickness
The Dec 2010 online issue of Kitplanes has a very good article explaining the problem and how to fix it.
Title of article > Morning sickness: It?s about sticking valves.
Tommy Turner
Fayetteville GA
RV-4 sold
RV-6 sold
RV-8 Flying
RV-14A building
10-24-2010, 08:32 PM
Textbook symptoms of a stuck exhaust valve.
Since it's a high compression engine, I'd advise borescoping it to see if the exhaust valve isn't burned. The rope trick, or even "staking" the valve with the rocker cover removed may only temporarily postpone the inevitable need to pull the cylinder off and send it to a cylinder shop for a proper fix.
Neal Howard
Airplaneless once again...
11-01-2010, 02:11 PM
Problem Fixed - Back in the Air
The problem was a sticking exhaust valve on #2. Valve was dropped into the cylinder, dragged out a the lower spark plug hole, and the stem was cleaned. Valve guide was reamed, and everything was reassembled - ground run & flight test, A-OK. The other three exhaust valves will be checked and the guides reamed (if necessary-sticking at all) at the next oil change.
Link to some helpful valve poop:
Everything You Ever Wanted to Know About Lycoming Valve Failures
http://egaa.home.mindspring.com/valves.html
