Old 10-13-2010, 02:32 PM
dnjfletch dnjfletch is offline
Default Adel Clamp Tool
The issue before last of Sport Aviation has an article on making a tool to help get the washer and nut on a bolt through Adel Clamps. It is just a V cut in the end of an old hack saw blade. Once you get the clamp(s) squeezed down using pliers or vice-grips, you can slide the hack saw blade in so it engages the first exposed bolt thread above the Adel clamp. That will hold the clamp in it squeezed down position while you get the pliers out of the way to put the washer and nut on. Sure wish I would have known about this 5 or 6 years ago!
Old 10-13-2010, 02:43 PM
N941WR's Avatar
N941WR N941WR is offline
For Adel clamp tips, see this thread.
In fact, you might want to post your tip to that thread.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 10-13-2010, 04:40 PM
scsmith scsmith is offline
Default nut catapults
If you make them too easy to install, we can't call them nut launchers anymore
But seriously, Bill's tip from 2006 comes in very handy - I don't even try anymore without making a safety wire lasso. You will spend 2 minutes to save 20, plus a lot of agrevation.
Steve Smith
Aeronautical Engineer
RV-8 N825RV
IO-360 A1A
WW 200RV
"The Magic Carpet"
Hobbs 625
LS6-15/18W sailplane SOLD
bought my old LS6-A back!!
VAF donation Jan 2020
Old 10-14-2010, 10:20 AM
rzbill's Avatar
rzbill rzbill is offline
Originally Posted by scsmith View Post
nut launchers
ROTFLMAO!!!
Now that is funny!
I was lasso-ing ADELS the other day after an unscheduled launch.
Bill Pendergrass
ME/AE '82
