Shouldn't be a problem
Mike,
If you were moving any volume of air through the tubing, then the diameter would indeed have a large effect as you would incur friction loss of pressure.
Since you are measuring a static pressure, you should not see any affect.
Now if you were to use a really small diameter tube or put in a really small oriface or restriction, you would then see a delay in the pressure equalizing from one end of the tubing run to the other as you are indeed moving a very small volume of air.
Jesse Bentley
N229Z - RV-8 - Flying - Livin' the dream!
