10-13-2010, 10:02 AM
spark plug gap
I couldn't find any specification of correct spark-plug gap in my engine manual. Where is this specified?
I have aviation spark plugs on my mag, and automotive spark plugs on my lightspeed... what gap value should I use for each of these? (O-320-D2A)
Phil
RV9A (SB)
Flying since July 2010!
Ottawa, Canada
10-13-2010, 10:16 AM
Phil,
Here's a thread on the L/S Denso plugs if that is what you have.
http://www.vansairforce.com/communit...ad.php?t=13254
Post # 14 may have info for you. Double check other sources, though.
Edit:
The following is right out of the Lightspeed Manual (section 2.6):
Engines normally timed at 25 degrees BTDC:
These are normally engines with compression ratios less than 8.7:1. Gap spark plugs fired by the CDI to .032"-.040".
Engines normally timed at 20 degrees BTDC:
These are usually engines with compression ratios of 8.7:1 or higher. Gap spark plugs fired by the CDI to .026"-.035".
Turbo / Supercharged engines should gap the spark plugs to .026” - .035” while turbo normalized engines should gap the spark plugs according to the compression ratio.
Sam Evans
RV7-A O-360 C/S
VAF#812
10-13-2010, 10:27 AM
Thanks Sam!
What about the aviation plugs? Will that info be in my magneto documentation?
Phil
RV9A (SB)
Ottawa, Canada
10-13-2010, 11:09 AM
Phil,
Someone will need chime in on the aviation plugs. I think it depends on the variety you have, etc.
Maybe check with your engine builder...? Sorry I couldn't be of help on that. I'm just not 'there' yet.
Sam Evans
RV7-A O-360 C/S
VAF#812
10-13-2010, 11:20 AM
Super Moderator
Set your avaiation plugs at .016.
Vic
 Vic Syracuse
Built RV-4, RV-6, 2-RV-10's, RV-7A, RV-8, Prescott Pusher, Kitfox Model II, Kitfox Speedster, Kitfox 7 Super Sport, Just Superstol, DAR, A&P/IA, EAA Tech Counselor/Flight Advisor, CFII-ASMEL/ASES
Kitplanes "Unairworthy" monthly feature
EAA Sport Aviation "Checkpoints" column
EAA Homebuilt Council Chair/member EAA BOD
Author "Pre-Buy Guide for Amateur-Built Aircraft"
www.Baselegaviation.com
10-13-2010, 12:00 PM
Vic
Does that .016 also apply to an O-360?
Sam Evans
RV7-A O-360 C/S
VAF#812
10-13-2010, 02:08 PM
Super Moderator
Yes. That works for that one, too.
Vic
 Vic Syracuse
