Old 03-14-2006, 09:48 PM
FlyerJumper FlyerJumper is offline
Lightbulb Is there an easier way to debur inside flanges?
Wondering what others have done to debur holes inside opposing flanges. There's not enough room between the two flanges to get a deburring tool in there and hand spinning a drill/debur bit is akward at best. (in the pic it appears I'm talking about the spar caps, but I'm talking about the spar flanges themselves) It didn't take too many holes to realize I'm probably doing this the hard way. Anybody come up with a quicker way?
Mark
RV-10
On again, Off again Building
...currently Off
Old 03-14-2006, 09:57 PM
szicree szicree is offline
You want a tool called a Cogsdill Burraway. It looks like a drill shaft with a little spring loaded blade poking out the side. Spin it in a drill and send it through the hole. It deburs both sides of the hole in one pass. They cost too much, but they are really cool.
Steve Zicree
Fullerton, Ca. w/beautiful 2.5 year old son
RV-4 99% built and sold
Rag and tube project well under way
paid =VAF= dues through June 2013
Old 03-14-2006, 09:58 PM
FLTENG FLTENG is offline
I found a 6 0r 12 inch 3/16 drill bit quite useful but still tedious
Old 03-14-2006, 09:59 PM
Ted Farmin Ted Farmin is offline
Default deburing
try a 90* snake and silver solder a bit to 1/4 28 stud. May need to get a friend with a lathe to get it put together straight.
Old 03-14-2006, 10:30 PM
avaviat avaviat is offline
I broke down and bought two burr-aways. Felt like an idiot for paying ~$60ea for glorified drill bits that won't even drill, but they are fast and can reach the back sides of holes. I don't know where people are buying them, but MSCdirect.com had the best price I found...
Before that, I had a stubby drill bit mounted in a length of fish-tank tubing (flexible vinyl hose) for reaching tight spots. It kinda worked.
For hand deburring I had a much easier time with a "standard" drill bit (#13 range, though the size doesn't really matter in this particular case) than any of the countersink-style deburring tools like in your picture. The drill bit did a better job too.
Jon
RV-8A, slowly but steadily.
Old 03-14-2006, 10:39 PM
aparchment's Avatar
aparchment aparchment is offline
Default burr-away is the way
The burr-away is the way to go. Deburrs both sides at the same time, and is quick and easy.
I bought mine on EBay and when I broke one (tipped the drill over and bent the tip) I ordered the replacement directly from the company. They were very nice people to deal with.
Antony
Old 03-15-2006, 05:18 AM
Rick6a's Avatar
Rick6a Rick6a is offline
Originally Posted by FlyerJumper
Wondering what others have done to debur holes inside opposing flanges. There's not enough room between the two flanges to get a deburring tool in there and hand spinning a drill/debur bit is akward at best. It didn't take too many holes to realize I'm probably doing this the hard way. Anybody come up with a quicker way?
Simple. By far the easiest way I have found to quickly debur those troublesome out of the way areas is to use a ball file or stone in my pneumatic pencil grinder. A Dremel tool with an appropriate accessory will work just as well.
Rick Galati RV-6A "Darla"
Old 03-15-2006, 05:25 AM
jcoloccia jcoloccia is offline
For the most part, I just use the deburring bit with a long extension. It's at a bit of an angle but it seems to work okay. This falls under the "we ain't making jewlery" category. When it gets too tight for that, I rub it with a little emery, and then a bit of scotchbrite. I'm not recommending this...it's just what I happen to do.
John Coloccia
www.ballofshame.com
Former builder, but still lurking 'cause you're a pretty cool bunch...
Old 03-15-2006, 08:23 AM
Default Thanks
Responses mucho appreciated.
Mark
RV-10
...currently Off
Old 03-18-2006, 04:48 AM
William Slaughter's Avatar
William Slaughter William Slaughter is offline
Burraway, definitely. My only regret is that I waited so long to buy them.
