  #21
Old 10-12-2010, 03:20 PM
N8RV's Avatar
N8RV N8RV is offline
This thread is HILARIOUS! I had completely forgotten that I'd done that ... but it's all coming back to me now ...
Don McNamara
Peoria, AZ
Builder: RV-8 "Smokey"
Old 10-12-2010, 04:33 PM
jsherblon's Avatar
jsherblon jsherblon is offline
I cut two left angle brackets, when I was supposed to make a left and a right. I even marked them "L" and "R" before cutting.
So... I tossed one of them into the scrap bin and then promptly made another left bracket.
Jim Sherblon
-7 Slider Finishing Kit
Stuck in Lodi CA
Old 10-12-2010, 07:57 PM
Bill Dicus Bill Dicus is offline
Default Goof
I did one whole side of a rudder skin, complete with rivet tape and beautiful flush rivets! Guess I should have noticed the rivets seemed a little long. Sure was pleased with myself - for a few minutes! Later managed to stretch the skin trying to fix a misplaced dimple. It now hangs in the hanger with our Pitts.
Bill Dicus
Shorewood (Milwaukee) Wisconsin
RV-8 N9669D Flying 12/4/14!
Flying Pitts S-2A, Piper Lance
Old 10-12-2010, 08:22 PM
videobobk's Avatar
videobobk videobobk is offline
I was so proud of that rudder skin that I laid in on the carpet and stepped back to admire it. My 90 pound Lab jumped right on the middle of it...
Then there was the time I had my son help me move the HS/elevator assembly. I totally forget I hadn't secured the fiberglass elevator tip he used to lift it. I left that dent on the trailing edge (all six inches of it) as a reminder.
Bob Kelly
Bob Kelly, Scipio, Indiana
Tech Counselor
Founder, Eagle's Nest Projects
President, AviationNation, Inc
RV-9A N908BL, Flying
Old 10-12-2010, 10:22 PM
Steve Barnes Steve Barnes is offline
Default Inverted Ribs
A few years ago there was a couple of builders who put the ribs on upside down on an RV8 spar. As I remember they didn't discover there mistake till the skins were riveted on. Now this one has bragging rights as one of the biggest errors you can make. I can kind of see how this could happen if you are totally focused finishing the wing and not thinking about how things go together.
Steve Barnes "The Builders Coach"
Old 10-13-2010, 04:29 AM
panhandler1956's Avatar
Default Nutplates
I have left nutplates out several times. So not only am I dumb, I'm not trainable either....
Brent Owens
Columbus, OH
RV-8 'Contrary Mary' flying
N784DE S/N #82614
www.fixedwingbuddha.com
Follow me on Facebook
Old 10-13-2010, 09:08 AM
longranger's Avatar
Also, once had to drill a few rivets out of the horizontal stab to retreive a bucking bar...
RV-7 TU 904KM (reserved)
Construction Log
Old 10-13-2010, 09:40 AM
shuttle's Avatar
shuttle shuttle is offline
Default Reversed HS Skins!
Miles,
Great one line "lost bucking bar in the HS" story. I have an HS story too.
Having match drilled both skins to the HS spar and ribs, then preped and primed everything, I riveted the skin to the LEFT HS SPAR & RIBS. Then I picked up the other skin. I was completely shocked to see the skin I was holding was marked up as the LEFT SKIN. I'd riveted the RIGHT SKIN upside down to the LEFT HS SPAR & RIBS - it fitted perfectly!
The story ends well as the LEFT SKIN also fitted perfectly upside down on the RIGHT HS SPAR & RIBS. Thankfully the HS skins are almost exactly symetrical and the prepunched holes are just about perfectly positioned.
Steve
Steve Hutt
West Sussex, UK
RV-7 G-HUTY (not flying yet)
( Tip-UP / TMX-IO-360-M1B / Hartzell 7497-2 / 1x LSE PLASMA III / Dual AF4500's / AF-Pilot AP / 695 )
