Old 10-10-2010, 08:00 AM
Kenny Gene Kenny Gene is offline
Default Beringer Front Rim support "Grove tube?"
My 7a tire is flat again (probably from the stickers at Weatherford) however I'm thinking of going with the Beringer tubless rim. I think the abrasion from the lower tire pressures wear out the tubes. Anyway, does anyone know, will the Beringer rim support the Grove nose wheel assembly with axle support tube?
Thanks.
Kenny Gene
RV 7a 294TC 585 hrs
RV 10 484TC Finishing
Old 10-10-2010, 09:08 AM
jferraro17's Avatar
jferraro17 jferraro17 is offline
Opulence, I has it...
The Beringer wheel is a complete replacement, with it's own axle. You keep the fork, nut and bolt.
Joe
Joe Ferraro
DFW, VAF #17
SOLD
Old 10-14-2010, 07:01 AM
Does the Beringer have a roll pin to keep the axle from spinning and also beefed up same as the Grove?
Thanks.
Kenny Gene
294TC RV 7a 585 hrs
484TC RV10 finishing
Old 10-14-2010, 07:25 AM
Walt's Avatar
Walt Walt is offline
Check out the "review" I did here:
http://www.vansairforce.com/communit...light=beringer
The beringer axle is a solid one piece axle that is captured between the forks, tighten down the axle bolt and no way the axle is going to spin so you really don't need the roll pins. IMO you didn't need the roll pins on the Grove either as it was also locked in tight by the forks and fully torqued bolt. The only one that really needed roll pins was the original matco because you left the bolt loose to adjust bearing preload.
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
Old 10-14-2010, 07:38 AM
Guy Prevost's Avatar
Guy Prevost Guy Prevost is offline
The Beringer does not need the roll pin. Everything said above is true. It is a really great upgrade.
Guy
Guy Prevost
Albuquerque, NM
RV-8a Built, Enjoyed, Sold
Two Kids: Built, Enjoying
RV-10, Bought, Rebuilt, Enjoying
Build / First Flight Video: http://www.youtube.com/watch?v=8f9HXzZT1dE
Build Log: http://websites.expercraft.com/geprevo/
Arguing on the internet is like having a competition to see who can hit a brick wall the hardest. You may win, but you're still an idiot.
Old 10-21-2010, 04:53 PM
jferraro17's Avatar
Incase you guys missed this, can you check this thread and add your advice on torque, please?
Joe
Joe Ferraro
DFW, VAF #17
SOLD
