Go Back   VAF Forums > RV Firewall Forward Section > Propellers
Old 10-10-2010, 07:35 AM
tx_jayhawk tx_jayhawk is offline
Default Sensenich Metal Prop Bolt Torque
Does anyone have the torque handy for the Sensenich metal prop (that Vans sells)? I have an 0-360 with the 4" extension (James cowl). I am thinking it is stamped on the hub, but the spinner plate is currently installed and I am hoping to avoid removed the prop bolts.
Scott
7A
Old 10-10-2010, 07:50 AM
N208ET N208ET is offline
Default 1/2 inch bolts
should be 60-65 ft. pounds
there should be a sticker on the side of the hub that has the torque value, I am pretty sure mine has it, take a look.
Randy
8A Flying
