10-10-2010, 06:51 AM
fuel flow at 1200rpm
During my 2 engine run yesterday, I took down some data during the brief run. Looks like I have some work to do.
Full rich Fuel flow at 1200rpm was showing 7gph, seems a bit high for an IO360, AFP, red cube feeding the info to a Dynon180.
any thoughts?
10-10-2010, 06:52 AM
What fuel flow difference did you see on/off fuel pump?
Kahuna
6A, S8 ,
Gold Hill, NC25
10-10-2010, 07:01 AM
boost pump was off. I didn't check it while the pump was running
10-10-2010, 07:27 AM
Brian,
What Kfactor did you set in the Dynon and where and how did you mount your cube, I can't remember?
10-10-2010, 07:39 AM
Brian, You will be calibrating the fuel flow during your test period. I had the Flowscan in mine and it took several flights to dial it in. It read way high at first. I changed to a Red Cube this spring and the K factor was right on from day one. Don
RV 7 N212MD Flying as of 12/22/2007
Backcountry/TCOW Super Cub flying 03/12/2011
Next project?
10-10-2010, 07:58 AM
any thoughts?
I think 2-2.5 gph would be much closer to reality, 7 is definately way high!
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
10-10-2010, 09:41 AM
I think I set the Kfactor=68000(will check today). Red cube mounted between the AFP body and fuel spider under #1cylinder. I'll be doing some checks next run up to see if it is even responding properly
10-10-2010, 09:58 AM
That setting shouldn't be that far off. We had to dial in an adjustment of about 3500 (lower) I believe. Can check if it is important.
Our O-320 show about .7-1.2 depending on how it is leaned.
Dave & Trina
RV-9A Flying  - 330 Hrs. Painted  Finishing the interior.
10-10-2010, 11:33 AM
This is another one that you can't have a one-FF fits all, for the prop load determines how much HP is required to give the rpm, which will be quite different for a CS in fine pitch vs a high-pitch FP prop.
