If the spar, and ribs have been riveted, then (IMHO) the wing needs the skin at least cleacoed on, or a few pop rivets might work.
The skin will protect the framework-----spar/ribs from damage.
Pop rivets will leave a smooth surface to deal with, vs. cleacos.
Either a wing cradle, or nose down on some padding, and strapped to the exterior wall of a truck body ----U Haul etc----should be a safe way to do it.
Where in Texas------maybe someone on VAF can meet up with the seller, and supervise for you??
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
