Old 10-07-2010, 11:25 AM
rph142's Avatar
rph142 rph142 is offline
Default NACA vent IN the cowl cheek
Would a NACA vent work if it was mounted in the cowl cheek? It wouldnt take much to cut and mount them to my fiberglass cowl cheeks.
Rob
Rob Holmes
www.myrv3.com
N59LG
The minimum number of planes one should own is one. The correct number is n+1, where n is the number of planes currently owned. This equation may also be re-written as s-1, where s is the number of planes owned that would result in separation from your partner.
- Veluminati
Old 10-07-2010, 11:38 AM
szicree szicree is offline
I would think that such a convex surface would be an area of low pressure. You might end up pulling air out of the cockpit.
Steve Zicree
Fullerton, Ca. w/beautiful 2.5 year old son
RV-4 99% built and sold
Rag and tube project well under way
paid =VAF= dues through June 2013
Old 10-07-2010, 03:13 PM
elippse elippse is offline
Is this for cabin air, engine or oil cooling? Don't use a NACA duct (curved divergent submerged duct) unless you have the design data and can size it appropriately for your application. There is also a parallel-wall sumerged duct that is part of the same family that is much better when you want very high duct airflow. It is better than the CDSD when the velocity of the air through the duct is 0.5 or greater than the free-stream velocity. It uses a square aperture which interfaces to a round duct easier than the 4:1 to 6:1 CDSD aperture and also uses the 7 degree ramp for best pressure recovery. It should be 8.1 times as long as the aperture height-width to give the 7 degrees. A steeper ramp than this invites separation.
Old 10-07-2010, 08:23 PM
KatieB's Avatar
KatieB KatieB is offline
Um, does that come in English?
Katie Bosman
RV-3B sold, but flying!
Next project: ???
Builders gonna build...
Old 10-07-2010, 08:40 PM
Well, Katie, that must be some of the Latin I got in Catholic schools showing through!
Old 10-07-2010, 08:50 PM
n5lp's Avatar
n5lp n5lp is offline
fugio ergo sum
Is this what you are talking about? I don't know how well it works, I just took the picture.
Larry Pardue
Carlsbad, NM
RV-6 N441LP Flying
Old 10-07-2010, 09:36 PM
Ironflight's Avatar
VAF Moderator / Line Boy
I thought of your recent pictures when I saw the question Larry - thanks for posting it! I do wonder how effective it is on that curved surface though - true NACA ducts are harder to implement than people think. In my case, I have other plans for the cheek cowls, so I am looking elsewhere for cooling air....
Paul
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 10-08-2010, 07:41 AM
Not sure if it works, but IMHO it doesn't look very good.
Steve Zicree
Old 10-08-2010, 07:45 AM
Dmadd Dmadd is offline
LOL!!!!!!
I was thinking the same thing Katie.
DM
Old 10-08-2010, 08:27 AM
rph142's Avatar
Yeah I thought they would look interesting there, then I happened across pictures of johns plane "hack job". I just talked to him about their effectiveness and it's sounds like they don't work very well at low pattern speeds. It looks like I'll be pulling fresh air from somewhere else. I might end up stuffing the inverted oil tank in the cheeks.
Rob Holmes
www.myrv3.com
N59LG
- Veluminati
