Old 10-06-2010, 06:21 PM
Noah's Avatar
Noah Noah is offline
Default Radio Ops Without Antenna Connected
Just finishing up panel wiring, but without wings on yet, some antennas are not yet connected. Is there any risk to running radios without all antennas connected? I'm not talking about transmitting here, just powering the radios on and checking local interfaces with ARINC & EFIS, etc. I checked Garmin's documentation and couldn't find anything about this. Just want to make sure that this isn't "so obvious" that they don't even list it (yeah right)!
Highest Regards,
Noah F, RV-7A
All men dream, but not equally. Those who dream by night in the dusty recesses of their minds wake in the day to find that it was vanity: but the dreamers of the day are dangerous men? for they may act their dream with open eyes, to make it possible. -T.E. Lawrence
Old 10-06-2010, 06:25 PM
Mike S's Avatar
Mike S Mike S is online now
Senior Curmudgeon
I am no expert, but as I understand it, as long as you do not transmit, it should not be a problem----at least to the radio.
Dont know how the rest of the little magic boxes of electrons will react.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 10-06-2010, 06:48 PM
Mel's Avatar
Mel Mel is offline
Default Right
No problem running the radios without antenna.
Do NOT, however, key the transmitter without the antenna. That can blow the output power section.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 10-06-2010, 07:05 PM
Walt's Avatar
Walt Walt is offline
As long as the 330 is not the ES model it's ok, but keep it in stby anyway.
Everything else should be ok, make sure you know how to recognize if the comm is transmitting in case you have a "stuck mic" situation.
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
Old 10-06-2010, 07:14 PM
Trevor778 Trevor778 is offline
Powering on your radio will not have any ill side effects on your system. But, as stated in the previous post do not transmit. The radio wave will be reflected back to your transceiver and cause serious damage. Better off to connect your antenna just as a precaution in case of a stuck ptt.
Old 10-06-2010, 07:41 PM
Noah's Avatar
Good point on the stuck mic, guys. I will definitely connect my com antenna temporarily, "just in case". Appreciate the quick responses.
Highest Regards,
Noah F, RV-7A
Old 10-06-2010, 07:42 PM
Walt's Avatar
Actually most modern low power comms (10W) are relatively immune to the output damage caused by an open antenna, not recommended mind you but chances are no damage will result from short term transmitting with an open antenna. On "Vintage" radios transmitting into an open antenna could certainly fry the output if done for to long.
The higher the power the more likely the damage, it can still be a problem on higher power (20W+) comms. The 330 for instance is 250W output, it can be damaged rather quickly if the antenna is not there, so keep it in stdby just to be sure it's not talking to anyone.
