Old 10-06-2010, 07:09 AM
diamond diamond is offline
Default Cost of operation comparison, -9 vs -12
I'm curious how the cost of ownership and operation compares between a -9 and a -12. Let's split the question into ownership costs vs operational costs. For the sake of comparison, lets assume the -9 will be flown no faster than the -12. Also assume that the -9 carries a 160 hp engine. Assume both are burning mogas.
Factor in any differences in insurance costs, annual inspections, etc.
Old 10-06-2010, 07:22 AM
Sam Buchanan's Avatar
been here awhile
Hangar cost will be the same, insurance about the same, and condition inspection could be higher for the RV-12 depending on the way it is registered and whether or not the owner is qualified to do the inspection.
But in the end, it will pretty much be a wash.
Sam Buchanan
RV-6
Fokker D.VII replica
Old 10-06-2010, 08:52 AM
647jc's Avatar
647jc 647jc is offline
Not to pick nits but there might be an issue burning mogas in a 160 hp Lycoming. Think you should consider a 150 hp (lower compression) Lycoming.
Joe Condon
Ankeny, Iowa
RV9A - 647JC - 300 hrs - SOLD 6/23/15
OneX - Under Construction - For Sale
Old 10-06-2010, 10:11 AM
So maybe it comes down to whether one can burn mogas in the -9 or not? It seems this has been batted around a bit and I'm still unclear whether there is currently an engine of 160 hp status that is a legimate, manufacturer supported mogas burner. If not, is there likely to be a more legimate option in 3 years when I would be deciding on an engine? (if I decide on a -9)
Can I assume that the -12 running at 130 mph would have the same gph fuel consumption as a 160 hp Lyc or Aerosport or other comparable engine burning mogas and running at the same speed?
Old 10-06-2010, 10:43 AM
been here awhile
A lot of 160hp O-320 engines have safely run mogas for many years.
Your second question; More or less.......yes.
Sam Buchanan
RV-6
Old 10-06-2010, 12:02 PM
az_gila's Avatar
az_gila az_gila is offline
Smile This would probably...
Originally Posted by Sam Buchanan View Post
Hangar cost will be the same, ......
...be reduced for the -12 if you took the wings off and used less hangar space....
Simple racks for storage, not a trailer.
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 10-06-2010, 12:34 PM
N941WR's Avatar
N941WR N941WR is offline
No issuesb with auto fuel in the 320 or 360. Check out this thread for details:
http://www.vansairforce.com/communit...ad.php?t=35765
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
