Old 10-02-2010, 09:51 AM
bret's Avatar
bret bret is offline
Default RV-7 wing rigging help
I am setting up the aileron bell crank and I do not have the jig to set the small push rod length, does anyone have the length of the jig measurement from the spar to the bolt hole so that i can make one?
Old 10-02-2010, 01:32 PM
bret's Avatar
Any one?........Any one?..........Bueler
Old 10-02-2010, 02:20 PM
robertahegy's Avatar
robertahegy robertahegy is offline
Moderator/Tech Counselor
Here is a shot of the jig with a t sq. for reference. Wasn't sure which direction you needed.
Hope this helps,
Roberta
Roberta Hegy
Built/Flew an RV-7A
Air Troy Estates, East Troy, WI
Ford Expedition and TRICE "Q"
Built Glen L "ZIP" Classic Outboard Runabout and Super Spartan Hydroplane
Glen L Torpedo
Old 10-02-2010, 03:31 PM
bret's Avatar
that is perfect, thank you so much.
Old 10-02-2010, 09:44 PM
yakdriver yakdriver is offline
Do yourself a favor and make two. It is a lot easier to set up all the linkages. Don
RV 7 N212MD Flying as of 12/22/2007
Backcountry/TCOW Super Cub flying 03/12/2011
Next project?
Old 10-03-2010, 05:39 PM
bret's Avatar
So how critical is this adjustment, I see in the pic that the gig is not flush with the square, is it 2 3/8" or 2 1/4" up from the spar, sorry, just asking, I know you don't want to over center the bell crank in any direction, and end up locked out.
Old 10-03-2010, 06:04 PM
bret's Avatar
nevermind, found it (2 7/16") on that big white paper thing e with all the pictures and #s on it.
Old 10-04-2010, 10:49 AM
I measured the jig and found the small hole center 23/32" from the edge and 2 3/8"from the other edge.
Roberta
Roberta Hegy
Built/Flew an RV-7A
Glen L Torpedo
Old 12-19-2010, 04:30 PM
Sig600 Sig600 is offline
I just started the aileron rigging install (**** W-818's). So you have to build the jig down in the plans?
Next?, TBD
IAR-823, SOLD
RV-8, SOLD
RV-7, SOLD
Old 12-19-2010, 04:42 PM
hydroguy2's Avatar
my QB wings came with a jig
