Old 10-01-2010, 10:55 PM
osxuser's Avatar
osxuser osxuser is offline
Default My turn, Converting D mag to NON D mag?
I have an O-360-A1A and an O-360-A1F6D. Anyone know if I can swap the accessory section with gears over to the A1F6D to convert it to an A1F6? I have an airplane that needs the A1F6 (certified requirements) and don't mind putting the D section on the A1A (making it an A1AD) and running one mag and one EI on the RV.
RV4 wing in Jig @ KPOC
RV7 emp built
Old 10-06-2010, 05:23 AM
mahlon_r mahlon_r is offline
Crankcase, crankshaft, gear train and accessory housing are different from each other and unique to each engine style.
Good Luck,
Mahlon
"The opinions and information provided in this and all of my posts are hopefully helpful to you. Please use the information provided responsibly and at your own risk."
Old 10-06-2010, 10:54 AM
osxuser's Avatar
Good Luck,
Mahlon
I cracked open my parts manual and was able to figure out the cranks were different, still runs the same p/n for the crankcase though from what I saw. Either way, too much work/trouble. Darn.
RV7 emp built
Old 10-06-2010, 01:28 PM
mikegraycmg's Avatar
mikegraycmg mikegraycmg is offline
Default Electronic DMag
If you are interested in electronic ignition, EMag (the makers of EMag and PMag) is working on a DMag, which should work on your engine or any "D" engine. I spoke to the folks there this afternoon, and they are looking to have their product out by the end of the year. That's what I am waiting for.
Mike Gray, A&P IA, AET, KGPM, Grand Prairie, Texas
1956 Bonanza for sale.
