Old 09-28-2010, 07:41 PM
Ironflight's Avatar
VAF Moderator / Line Boy
Default Isn?t This a Desert?!
We fly one of our RV?s (or the other) out from Houston to Southern California several times a year. The shortest route being a straight line, we head for El Paso, passing just to the north of the city (and south of the big White Sands Restricted Area), then on to Casa Grande (south of Phoenix) and Big Bear Lake (about 5,000? higher). We usually stop in West Texas for fuel before getting to the more-expensive El Paso area, then hit Casa Grande for another inexpensive fill-up before going to the mountains. We could do it in two hops, but why push it, only to pay more for the gas? The return trip is more often made with tailwinds, and is frequently a two-hop, unless ( of course) you have to start dodging weather. Which, unfortunately, we always seem to do.
The problem is that out there in plains, the West Texas ?desert? seems to manufacture huge ? nay, monstrous ? storms. It doesn?t even seem to make a difference what time of year, so long as it isn?t the dead of winter. And if you leave the west coast at sunrise, it is early afternoon (do to flying against the sun) by the time you cross the Franklin Mountains and head out for the Hill Country. That gives the weather a chance to set up the ambush. This trip was typical. The forecast was for a ?smallish? line of weather from El Paso up to the northeast, all the way to Wichita Falls and beyond. Not big, dark stuff ? just a general area of light green on the map. But it sure looked like a typical Texas Line Dance in my mind.
Leaving El Paso behind, we had a clear view of the volcanic cones to the east, and of the Salt Flats beyond them. I had climbed to 9500 feet to make sue I was over the El Paso airspace, but shortly thereafter, saw a layer of clouds ahead with bases a little lower. Not wanting to go on top because there were cumulous up ahead (and I knew we?d never get over them), we descended to 7500 to stay clear. That worked for a little while, but they kept getting lower. Uh-oh?.this looked familiar. Up ahead was Guadalupe Pass and the old buried ref that extends south towards Van Horn. While it might seem that the land keeps getting lower as you go from El Paso to the coast, it isn?t true ? there is a buildup known as the Davis Mountains that you have to get over before the flat plains begin near Pecos. And for some dang reason, the clouds always start dropping down as the terrain rises!
Visibilities are usually great below the clouds ? except in the rain showers of course. XM really, really helps here ? we could see spotty showers up ahead ? greens and yellows, occasional widely scattered cells of more concern, but not on our course. I rarely use the Satellite image of the clouds, but in this case, it seemed accurate, portraying a line of clouds that correlated to the rain showers from about Guadalupe to the other side of Fort Stockton. Where on the other side? Well, there aren?t actually any more landmarks until you get to Senora, so let?s just say about 50 miles. I-10 is about the only thing out there, and a welcome site to put a little perspective on the otherworldly terrain.
We had to get down to about 2,000 AGL to stay under the darkening skies, but the terrain shown on both the GRT EFIS and the Garmin 696 gave me a road-map of where the low points were. Very, very useful these electronic toys! (of course, you can always follow that intestate as well?) I spent about 20 minutes jinking around cells and terrain, mapping a route generally to the east. Pecos disappeared under a blossoming red cell, but I really didn?t want to go there anyway ? the runways seem to be under some sort of reconstruction, according to the NOTAMS. Fort Stockton was an ironclad bailout if the METARS (and Radar) could be believed, but we passed north of it, not getting a look. Shortly thereafter, the clouds above went broken, and I could see that the tops were much lower ? we were through the line that puzzles me so much. I thought this was supposed to be a desert! How can that be when it seems to storm every single day?!
Why not file IFR and avoid the scramble down low? Because I hate bouncing along inside building cumulous and avoiding the storms while riding the bucking beast. Outside of my comfort level. As long as I can see well underneath, and have a couple thousand foot ceilings, I?ll take the low road when the clouds go vertical. It can be mighty pretty down there, with shafts of sunlight on the rugged hillsides. I like the ability to juke and jink as required without waiting for a clearance revision. Of course, flying down low in an RV takes away that fuel and speed advantage, so we had to put in to Junction for gas ? but that was OK, we needed to let the afternoon round of coastal thunderstorms die down at home before we got there anyway. This trip, our timing was perfect, with the shows dissipating just in time to show us a rainbow as we crossed the southwest side of Houston and slid in to Polly Ranch.
So much for the idea that the deserts of West Texas never get rain! What I want to know is ? what the heck do they do out there with all that moisture? They sure hide it well?..
Paul
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 09-28-2010, 09:40 PM
Casey Stewart's Avatar
Casey Stewart Casey Stewart is offline
Default I understand
Having only had low and slow planes before the -7 cross country flights were out of the question. Here in the pacific N.W. weather is easily judged by common sense and its the same all around. Rain here, same there. This summer the -7 flew to oshkosh and got to experience midwest weather. Fun to see the difference some big jagged rocks can make
Casey D. Stewart
RV-7 N957RV (right seat if I am lucky)
C-150 N4265C for the PPL
Old 09-28-2010, 11:02 PM
Bavafa Bavafa is offline
I will be on a x-country flight from CA to Atlanta this Friday and really looking forward to it, as this would be my longest x-country flight in the RV. I have been checking the weather and it seems fair amount of rain over OK/AR area each day. I don't know what are the tops for those cells and debating to file IFR or just go VFR. My only reservation with filing IFR is that you can't deviate from course or altitude much if you encounter cells of rain.
Any suggestions/thoughts?
Mehrdad
N825SM RV7A - IO360M1B - SOLD
N825MS RV14A - IO390 - Flying
Dues paid
Old 09-29-2010, 10:46 AM
RV6airplanePilot's Avatar
RV6airplanePilot RV6airplanePilot is offline
Default Enroute controllers often very accommodating
[quote=Bavafa;471377] My only reservation with filing IFR is that you can't deviate from course or altitude much if you encounter cells of rain.
I flew from Los Alamos to Houston this summer on the 4th of July when we had all that moisture from the Gulf hurricane. The controllers were super. I had to deviate a handful of times, all approved immediately. Later that day I was going past Pensacola VFR and ran into poor weather, JAX helped me thru that too on a pop up basis. There are a few congested areas I prefer to be VFR: Atlanta, Charlotte, Orlando. And those are better IFR than flight following.
Old 09-29-2010, 10:56 AM
Lars Lars is offline
Great writing as always, Paul, but... man, you gotta get some pictures to go with a narrative like that!
Lars Pedersen
Davis, CA
RV-7 Flying as of June 24, 2012
960+ hours as of June 30, 2020. Where did the time go?
Old 09-29-2010, 11:30 AM
Louise Hose's Avatar
Default Drag out some old photos
Paul, I don't think either of us took any photos this time but you could easily drag out photos from a multitude of previous trips across the landscape.
Old 09-29-2010, 02:34 PM
Mike D's Avatar
Mike D Mike D is offline
Default Here is a photo of about the same time as Paul's trip
Paul,
I know what you mean. On my way to the San Francisco area, I went through Pecos. Both coming and going it was just like this.
What you see here is me just off after getting fuel and a burrito at Pecos. (great fuel stop) I am under the overcast headed west toward the higher terrain. (note the hills in the background)
Love the GPS and GRT that let me know I would not make it out of this valley without finding a hole through this.
Michael Delpier
RV6A -O-320, fixed pitch, GRT Sport, 496
RV-10 - working on finish kit
Houston
Old 09-29-2010, 03:51 PM
RVbySDI's Avatar
RVbySDI RVbySDI is offline
Mehrdad,
Not too sure what you are seeing on the weather in OK. This weekend is looking severe clear and in the mid 70's in Oklahoma. Maybe there is supposed to be something pop up east in Arkansas. If it does just stop in at KOJA and visit with us at LOE.
RVBYSDI
Steve
RV9A
https://rvwings.com
Live Long And Prosper! 🖖🏻
Old 09-29-2010, 06:34 PM
Originally Posted by RVbySDI View Post
Mehrdad,
Steve,
Thanks for the invite, I may just take you upon that as it is right on my way that I have planned. And you are right about the weather, it seems to be good weather all the way where as last week I was seen much rain on my path. Is the event right at the airport KOJA? I will see if I can find a hotel nearby and stay there for a day.
Mehrdad
Dues paid
Old 09-30-2010, 10:47 AM
RVbySDI's Avatar
Steve,
Yes LOE is on the KOJA airport. Click on the link to see the AirNav data on the airport.
RVBYSDI
Steve
RV9A
https://rvwings.com
