Go Back   VAF Forums > RV Firewall Forward Section > Alternative Engines
Old 09-28-2010, 12:49 PM
JDanno JDanno is offline
Default ??? on probes again...
Okay! Sooo, the stock block has various probes (water temp., oil pressure, etc.) going to the ECU. Would it work okay to splice into the wiring right after the probe and then run the wires to the EFIS so that the various functions can be monitored on the EFIS??? Would it degrade the signal output to where the ECU would have trouble reading it? I know that on the oxygen sensor I've seen where that can be done but nothing on the others. What do you think?? The alternate would be to install a second set of probes run to the EFIS which is doable. But I want to avoid if possible. Thanks, Dan
Old 09-28-2010, 02:04 PM
dieselgeek dieselgeek is offline
Temp sensors, not easily - you'll change the bias of the signal going into the ECU. Most 0-5v sensors (Throttle Position, sometimes Cam or Crank position also) sensors usually CAN be shared, but might need a pullup resistor if there is too much current drain on the sensor.
Old 09-30-2010, 02:08 PM
SHIPCHIEF SHIPCHIEF is offline
Seperate is good. Sharing the sensor data from the engine control with a monitor means potenetial new problems with engine control.
Engine control is nearly as important as flight control.
Separate sensors wouldn't be much heavier, if available mountings exist on the engine for them...Try to limit the number of critical failure sources.
Scott Emery
http://gallery.eaa326.org/v/members/semery/
EAA 668340, chapter 326 & IAC chapter 67
RV-8 N89SE first flight 12/26/2013
Yak55M, and the wife has an RV-4
There is nothing-absolute nothing-half so much worth doing as simply messing around with Aeroplanes
(with apologies to Ratty)
2019
