Old 09-28-2010, 05:03 AM
carguy614's Avatar
carguy614 carguy614 is offline
Default ECI cylinders, Auto plugs, and Pmag question.
Hello group,
I am using ECI experimental tapered barrel cylinders on my O-320 engine rebuild. They are equipped with auto plug (14mm) plug holes, and I will use Pmags for ignition. I am curious as to which spark plug number I should start with. Hard to accurately measure the plug reach for this application, and as of yet, I have been unable to verify the reach reading all of the info from ECI that I have found. Any suggestions??
Thanks so much,
Chris
Chris Schmitt
Shallotte, NC
RV9A 90970 N614RV
Sold to nice folks in Texas and badly missed.
RV9 in progress
Old 09-28-2010, 05:18 AM
apkp777's Avatar
apkp777 apkp777 is offline
I am using BR8EIX Iridium plugs. I just switched from BR8ES. The Iridium's are $8/each compared to about $2 for the others. Still I think the Iridium's are a good choice. My BR8ES were showing a bit of deteriorating after 100 hours.
Tony Phillips
N524AP, RV 9 (tail wheel)
Last edited by apkp777 : 09-28-2010 at 01:34 PM. Reason: replaced deodorizing with deteriorating?
Old 09-28-2010, 12:06 PM
chuckwn's Avatar
chuckwn chuckwn is offline
Default Auto Plugs
I have had good luck with Denso W27ESR-U for the last 1500 hours. Cost less than $2 each. Here is a handy link: http://www.clubplug.net/denso_ngk.html
Chuck Newman
Petaluma, CA
RV-8 N828RV
Old 09-28-2010, 02:38 PM
Walt's Avatar
Walt Walt is offline
I use IK27 with my LSI, but without the adapters do the heads still use the long reach plugs?
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
Old 09-28-2010, 04:49 PM
apkp777's Avatar
Okay, today was my second flight and second attempt to confirm performance results.
I switched from BR8ES to BR8EIX plugs and on my first flight I noticed that the engine leaned to PK with no roughness.
Today's flight I wanted to see if that was a fluke or if I could repeat it. Previously at PK EGT the engine would run very rough and you would have to be deaf to continue without enriching the mixture. It was uncomfortable rough. Today I leaned to PK and the only indication was that the SkyView showed PK and the RPM began to drop off. As I continued to lean the "PK" changed to LOP and I was able to lean to 50 degrees LOP (probably could have gone further). Other indications were; a drop in CHT and EGTs as well as a balancing of all the cylinders. The engine continued to run smooth and I repeated the results at various power settings from 40-65%. I used 1/2 to 3/4 carb heat and no carb heat. Carb heat did seem to help balance things.
Tony Phillips
