Old 09-27-2010, 09:18 PM
jimspry jimspry is offline
Default Manifold pressure problem
I am getting fuel in the clear plastic manifold pressure line aft of the firewall. It blocks the line and I lose the manifold pressure reading (it slowly falls to zero) in flight. This has been a problem from hour one. I now have 95 hours on it. After clearing the line it might go 10 plus hours with no problem, then it plugs again. Any ideas?
Old 09-28-2010, 03:14 AM
AltonD's Avatar
AltonD AltonD is offline
where are you getting your manifold pressure? #3 cylinder?
Alton DeWeese
N526RV RV7A Tip Up, IO360 180 W/Hartzel BA prop.
Flying ~950 hours since Aug 2010
N4IDH
Construction Log
?The secret of getting ahead is getting started. The secret of getting started is breaking your complex overwhelming tasks into small manageable tasks, and then starting on the first one.?
?Mark Twain
Old 09-28-2010, 04:29 AM
Default manifold press. problem
Yes, #3 cyl. and using van's man. press. kit.
Old 09-28-2010, 04:57 AM
carguy614's Avatar
carguy614 carguy614 is offline
Default manifold pressure
I have actually seen this issue once before. In that case, the transducer was mounted lower than the port fitting on the cylinder (no.3) causing fuel to pool in the line. Is your transducer and line passthrough high enough on the firewall?
Hope this helps,
Chris
Chris Schmitt
Shallotte, NC
RV9A 90970 N614RV
Sold to nice folks in Texas and badly missed.
RV9 in progress
