Old 09-27-2010, 06:57 PM
SteveHRV7 SteveHRV7 is offline
Default Window defogger/defroster
How many of you have installed some type of window defogger/defroster?
I am at a stage where if I want to install some type of fan or airflow directed up onto the windshield I should do it now. I searched the threads but most of the posts are several years old. There seem to be 4 possibilities:
1. Don't install anything - its not a problem
2. Passive heating - warm air convects up through a hole in the glare shield
3. Active heating via airflow from a small scat tube directed at the window
4. Active heating via a fan of some type
Recommendations, advice, thoughts...
Thanks!
Steve Houghton
RV7a
Okemos, MI
N807SH
Old 09-27-2010, 09:15 PM
L.Adamson's Avatar
L.Adamson L.Adamson is offline
I have a 12 volt computer fan mounted under the glare shield (slider). No ducting, although I made a triangular shaped hood, which I don't use. Whenever the windscreen has fogged up during taxi, I flip on the switch, and it immediately clears. I'll just assume it's better to have one, than not.
L.Adamson --- RV6A
Old 09-27-2010, 09:23 PM
kevinh's Avatar
kevinh kevinh is offline
I went for your option #3. And _very_ occasionally I develop fog on the windshield after engine start. No problem - I just crack the canopy and do my preflight checks. By the time I've done my runup the fog is gone.
-kevinh, Track my RV-7A, flying, alas, sold in 2013 after 450ish hours. (I'm now building something different)
Old 09-28-2010, 07:40 AM
sbal0906's Avatar
sbal0906 sbal0906 is offline
How warm do the electronic components in the instrument panel get? Can a fan be used to draw warm air from the instruments toward the windshield?
Shamit Bal
http://www.flyaroundthesun.com
RV-9A
Started on wings.
Winnipeg, Manitoba, Canada
Old 09-28-2010, 08:24 AM
yakdriver yakdriver is offline
I have a 3" computer pancake fan and it works great. It is mounted over the radios so it pulls a little heat off them plus the heat from the heater. Don
RV 7 N212MD Flying as of 12/22/2007
Backcountry/TCOW Super Cub flying 03/12/2011
Next project?
