Fuel Tank: INBD end ribs assembly; MEK vs Acetone
Hi all,
I notice when I worked on the inboard end ribs for the tanks, there is a tooling hole in the aft, next to one of the platenut. I can imagine that hole will be a source of leakage, does anyone has any problem with that tooling hole?
Also, does anyone put any sealant between the rib and reinforcement ring? The manual specify sealant is not necessary between the two because the cork gasket will stop any leakage, does anyone has any problem in that area?
Lastly, can I use acetone instead of MEK for cleaning the tank for sealant application?
Many thanks!
Hank
Hank Cheng
RV8 Super Slow Build Kit
Titan IOX360, Catto 3 Blades RV prop, Full Dynon everything + Garmin GTN650
First RV in Hong Kong
First Homebuilt aircraft registered in Hong Kong "B-KOO"
Completed RTW journey in 2016
Built with a group of High School Students
Aircraft donated to the Hong Kong Science Museum
In memory of Michael Tam
