Old 09-27-2010, 09:15 AM
HighSchoolBuilders HighSchoolBuilders is offline
Default Fay sealing method
Greetings!
After much consultation with many fellow builders, I am planning to seal my tank by fay sealing method.
My understand is that, instead of rivet the parts together before the sealant cures, I cleco everything together with cleco in every single holes. Wait for it to cure and then final rivet them together.
My concern here is that, cleco doesn't hold the parts together as good as rivet, especially with those ribs being so tough to fit. If there is a small gap with the sealant cures, would that cause any problem with I final rivet the parts together?
Thanks!
Hank
Hank Cheng
RV8 Super Slow Build Kit
Titan IOX360, Catto 3 Blades RV prop, Full Dynon everything + Garmin GTN650
First RV in Hong Kong
First Homebuilt aircraft registered in Hong Kong "B-KOO"
Completed RTW journey in 2016
Built with a group of High School Students
Aircraft donated to the Hong Kong Science Museum
In memory of Michael Tam
Old 09-27-2010, 09:25 AM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
http://www.vansairforce.com/communit...ht=fay+sealing
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 09-27-2010, 09:34 AM
Default Thanks!
Thanks Mike!
Hank Cheng
Old 09-27-2010, 12:32 PM
bkthomps bkthomps is offline
you can get a set of 8-32 nuts to put on the end of your clecos if you want them to snug up tighter
