I have the SP-200 and it uses either the
Nicad pack at 9.6 vdc/600 mAH or 8 ea AA batteries x 1.5 volts= 12.0 vdc. The cig lighter adapter allows you to power it w/o any batteries in it at all from either 12, 24 or 28 vdc aircraft systems. I did not buy adapter because it is in my flight bag for emergencies/radio failure only. I recharge pack every month or two.
If it is the same on the SP-400 then 9.6-12.0 vdc.
Good judgment comes from experience, and a lot of that comes from bad judgment.
