Old 09-25-2010, 04:43 PM
Walt's Avatar
Walt Walt is offline
Default Info Needed, Van's Std arm lengths for NLG, Tail wheel & MLG
Need gear location Arms for the following models please, just look in your manual for this info:
(for W&B spreadsheets)
8, 8A, 9, 9A, 10, 12
Thanks!
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
Old 09-26-2010, 02:24 PM
Rick_A's Avatar
Rick_A Rick_A is offline
Walt, I've got a set of 9 plans if you want the W&B worksheets.
For -9
Rt Main - 68.625" aft of datum
Lt Main - 68.75"
Tail - 244.75"
For -9A
Rt Main - 91.88
Lt Main - 91.88
Nose - 34.5
For both:
Datum 70" forward of leading edge
Design CG 77.95 - 84.84 aft of Datum
Recommend Gross - 1750 lbs
Utility Gross - 1600
Rick Aronow,
A&P
Flying 7A Slider;
RV-12 SOLD
Highland Village,TX
Old 09-28-2010, 04:17 PM
Walt's Avatar
Still need data for the 4, 6 and 8A, come on folks.... help a brutha out
