eci filter adapter
Scott I have the eci adapter, and the only problem I have is I can't use the longer oil filters, it would hit
the engine mount.. another 1/2 would be perfect for
my setup rv9a 0320 , I am using a machanical Tac
drive / cable.. as a back up to the dynon d-180
plus I got a good deal on it.. anyway I don't know exactly how the transducer works but if it connects
like a cable would, then the adapter has a rounded
cutout area on mine for the cable or whatever connects to that output shaft.. hope this helps..
I am will just use the shorter filter to start, if that doesn't work out then 1/2 spacer would be much
better , plus it would be easier for the filter change, keeps it away from running down the acc case..
Danny..
