Old 09-23-2010, 08:01 PM
rjaflys rjaflys is offline
Default Rudder Trim
Can someone give me the contact info for the manufacturer or supplier of the plastic, glue on, rudder trim tabs. Thanks, Bob.
Old 09-23-2010, 08:25 PM
L.Adamson's Avatar
L.Adamson L.Adamson is offline
Here's one.
http://www.averytools.com/pc-118-112...-trim-tab.aspx
Old 09-23-2010, 09:08 PM
schristo@mac.com's Avatar
schristo@mac.com schristo@mac.com is offline
Default you might try a tweak to a gear leg fairing...
i found that as little as 1/64" of an inch difference in the position of a gear leg fairing would impact trim about a ball width... pretty amazing. you might give a try to making a very minor change in the rotational position of a gear leg before committing to attaching a wedge to the rudder.
Stephen
RV7 powered by a lycoming thunderbolt IO-390
turning a whirlwind HRT prop
with more hours flying than building... 2,430 on the hobbs!
ORCA Flight
Race 771
margarita!
Old 09-23-2010, 10:01 PM
L.Adamson's Avatar
My 6A has a vertical stab that is installed straight, instead of with an offset like most newer models. It's a fact of life, that 6's such as mine will need a wedge or tab. I originally cut a small wedge out of wood, and duct taped it on. This worked great for a few months. Later I rivited on a fixed rudder tab.
L.Adamson --- RV6A
