Old 09-21-2010, 07:07 PM
RobinHou RobinHou is offline
Default Install cowl without an engine?
I am working on my wings so I am still far away from installing engine cowl. It is my understanding that cowl is to be fitted after the engine is already on its mount. However, I saw this ad today: http://www.barnstormers.com/ad_detail.php?ID=472603
So, it looks like it is possible to fit the cowl before installing the engine. If so, that will be my choice because I want to delay my engine purchase for as long as possible.
How dose one go about installing the cowl before mounting engine?
Thanks in advance,
Robin
Old 09-21-2010, 07:10 PM
hydroguy2's Avatar
yes, it can be done. I think Jay Pratt has a mock up jig he uses for cowl fitting
Old 09-21-2010, 07:28 PM
az_gila's Avatar
az_gila az_gila is offline
Smile If you have the $$$ this...
...would work...
http://www.precisionairmotive.com/mockupengines.htm
However, if you are not working on the baffles, ask your local engine rebuilder if he has a reject case and a reject crank.
The O-360s and O-320s are the same length, and all you need is something to hold your fake wooden spinner bulkhead in the correct position...
Make sure the case has the same mount as you plan on using - probably dynafocal.
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 09-22-2010, 07:08 AM
Jaypratt's Avatar
Jaypratt Jaypratt is offline
Default Cowl
Robin,
I have an engine case and crank that I use to fit cownings. E Mail me and I will send you a picture. I am fitting one now.
I use the spinner rear bulkhead with a plywood spacer to simulate the prop. It is a lot easer to fit the cowl without the jugs on the engine, you can get your hands inside to back up your drilbit.
jay-pratt at sbcglobal.net
Jay Pratt VAF #2
RV Central - Builder Assistance
Paul Revere, Borrowed Horse, & Shooter
Old 09-22-2010, 03:21 PM
jrs14855 jrs14855 is offline
Default mock up engine
I bought a non repairable case and crank for less than $100. Check with the specialty shops-Divco and CSI for the case and ASI for the crank. You will also need some main bearings.
Old 12-04-2012, 10:10 PM
IowaRV9Dreamer's Avatar
IowaRV9Dreamer IowaRV9Dreamer is offline
Default Looking for scrap engine isolators
I want to fit my cowl without my engine, or at least without the whole engine. My engine is a disassembled core, so I'd like to assemble the case, cranks, and main bearings only and mount the whole thing on the engine mount (which is already attached to the fuse).
The plan would then be to fit the cowl, and when it is done I can remove the engine and overhaul it right before first flight.
Does anyone have a set of old or scrap engine mount isolators that they'd like to sell or donate? I'd rather spend my money on stuff I need right now instead of buying expen$ive Lord mounts right now.
Dave Gribble VAF #232
Building RV-9A N149DG (slider, IO-320, IFR)
Restored and Flying Beech Super III N3698Q
Marion IA
Struggling with fiberglass
There is no sport equal to that which aviators enjoy while being carried through the air on great white wings." Wilbur Wright, 1905
Old 12-04-2012, 10:41 PM
txaviator's Avatar
txaviator txaviator is offline
Originally Posted by Jaypratt View Post
Robin,
Jay has THE way! If you can find a local non-usable case and crank, follow his lead! I've seen this setup at his facility and it is REALLY neat how it all works!
Gary Robertson
Arlington, TX
RV-12 Built / Sold / Flying
Currently Flying: Cessna Skyhawk 172
Rebuilding a true barn find J-3 Cub
Old 12-05-2012, 02:13 AM
Doug's Avatar
Doug Doug is offline
You might want to simulate the mass of the engine and prop, otherwise you will need to allow for engine 'sag'.
Doug Gray
RV-6 completed, flying since July 2010
Old 12-05-2012, 04:00 AM
MauiLvrs's Avatar
MauiLvrs MauiLvrs is offline
The other way is to....
Install the cowl and make it streamlined...
And install two of those SubSonex engines on the tail
Dave & Trina
RV-9A Flying - 330 Hrs. Painted Finishing the interior.
