Old 03-11-2006, 07:32 AM
Will Womack Will Womack is offline
Default -7 Rudder Blind Rivets
The plans call out an optional blind rivet CS4-4 to attach the rudder control horn support bracket to the skin and bottom rib. However, the solid rivet callout is 3-4. For those that used the optional rivet, did you enlarge the holes to 1/8" (from 3/16")?? This doesn't seem right to me.
Thanks in advance.
Will Womack
7A 72452 Wings
\_____@(")@_____/
Old 03-11-2006, 08:13 AM
MTBehnke MTBehnke is offline
Will,
I believe the CS4-4 is correct, but you'll need to decide now whether you will use the solid or blind rivets, both for hole and dimple size.
On my -9A I planned on using the CS4-4's there, but didn't think to enlarge these holes nor use the larger dimple dies. Now I can't use the blind rivets, but last night managed to get a bucking bar in through the brace hole for the two middle rivets.
I'm now trying to figure out how to get a bar on the front and back rivets inside the horn. The forward one is tricky because the nut plate interferes a bit, and the rear one is simply in a tight corner.
Anyone have suggestions on a bucking bar I can get in there with?
Mike Behnke
RV-9A Empennage
Andover, MN
Old 03-11-2006, 08:45 AM
dan's Avatar
dan dan is offline
Longeron yoke
Dan Checkoway RV-7
Old 03-11-2006, 11:16 AM
robertahegy's Avatar
robertahegy robertahegy is offline
Moderator/Tech Counselor
I second the longeron yoke idea.
Roberta
Old 03-11-2006, 12:54 PM
jcoloccia jcoloccia is offline
I believe the plans allow you to use LP4-3's there. I wussed out and did that, but I also did it on another rudder with the longeron yoke just fine.
John Coloccia
www.ballofshame.com
Former builder, but still lurking 'cause you're a pretty cool bunch...
Old 03-11-2006, 01:25 PM
dan's Avatar
dan dan is offline
LP's aren't flush (lo-profile "dome" rivets). CS's are (CounterSunk) and are flush.
DWG 7 calls out "AN426AD3-4 (CS4-4 OPTIONAL) ALL R-901 SKIN TO R-904 BOTTOM RIB TO R-710 HORN BRACE RIVETS"
Dan Checkoway RV-7
Old 03-11-2006, 03:12 PM
As usual, you're right Dan. I was talking about the rudder horn to horn brace rivets. I wussed out on the ones in question too, though, and used CS4-4's
John Coloccia
www.ballofshame.com
Old 03-12-2006, 07:52 AM
John,
When you installed the CS4-4 do you remember if you enlarged the holes early on, or after dimpling. I don't think it is really an option for me now. Unless I were to enlarge the holes and redimple. Not sure how well that would work out.
Would probably be a whole lot easier to head over to the tool crib and try and borrow the longeron yoke
Will Womack
7A 72452 Wings
\_____@(")@_____/
Old 03-12-2006, 10:19 AM
dan's Avatar
dan dan is offline
Default 110 degrees
I'm pretty sure CS4-4 have 110-degree heads. I personally would dimple the #40 holes, then enlarge to #30, and then run the deburring tool in each hole a few times until the CS4-4 sits flush. It's a combo of dimpling and c-sinking to get it "mostly right" while removing as little material as possible.
Somewhere out there you can find 110-degree countersink cutters, but in my opinion I wouldn't waste the money. Even Van's makes note of this in their construction manuals in various spots, that the CS4-4 isn't a perfect fit in a 100-degree dimple/c-sink, but it's a compromise that we can live with.
Call Van's if you're unsure.
Dan Checkoway RV-7
Old 03-12-2006, 12:40 PM
This is pretty much EXACTLY what I did because I didn't realize until later what a pain those last couple of rivets are. I think the rivet was still a little proud was I was done because I didn't want to cut too much (just a couple of turns), but if I remember right it gets covered by the fiberglass tip, or at least a reinforcing strip of glass anyhow (assuming you're going for the "smooth" look). It looks a little funny, but seems to be functional non the less.
Speaking of when to drill/dimple stuff, I've been pre-drilling and dimpling many of the tip attach holes in the elevators. It's already pretty tight in some spots even before I rivetted the skin, so I figured it might be downright impossible after rivetting. Am I the only one who's doing this, and is there some potential gotcha' that I'm missing?
John Coloccia
www.ballofshame.com
