Old 09-21-2010, 10:30 AM
nippaero's Avatar
nippaero nippaero is offline
Default Manual in electronic format???
Has anyone ever inquired to Vans about the availability of a manual in electronic format? PDF or otherwise? It would be great having access to it on my computer when traveling.
A&P
RV-7 (Sold)
RV-6 (Sold)
1952 Cessna 170B
1947 Aeronca Chief
Old 09-21-2010, 08:10 PM
Bubblehead's Avatar
Bubblehead Bubblehead is offline
Default Even better
How about a way to convert a PDF POH to a book that could be downloaded into an iPad?
RV-8 180 hp IO-360 N247TD with 10" SkyView!
VAF Donations Made 8/2019 and 12/2019
"Cum omni alio deficiente, ludere mortuis."
(When all else fails, play dead.)
Old 09-22-2010, 12:01 PM
danielhv's Avatar
danielhv danielhv is offline
I'd like to know this too... the shop fans have had their way with the pages in my manual. I think most of them have torn ring binder holes.
Old 09-22-2010, 12:13 PM
Bill Wightman's Avatar
Bill Wightman Bill Wightman is offline
A friend of mine used some kind of fancy high speed scanner to put the 7/7A plans into .PDF format. It's even searchable text. Super hi-res too.
Unfortunately I think it's illegal to distribute....
?The important thing in aeroplanes is that they shall be speedy.?
- Baron Manfred von Richthofen
RV8 under construction
RV4 - Sold
United B777 FO, Chicago
Aero Engineer
RV8
Old 09-22-2010, 01:28 PM
danielhv's Avatar
Yea I had mine scanned too... they are semi-searchable... the OCR wouldn't pick up everything in them, but it works.
I'd have no problem sending my scanned plans around so long as the recipient was able to prove to me that they were in-fact a builder and had the physical plans already but just wanted a portable electronic copy for the occasional slow-at-work days.
Old 09-22-2010, 02:03 PM
DCat22's Avatar
DCat22 DCat22 is offline
Yalp, I understand that Van's may be leery of letting the plans/manual out electronically, but that genie is already out of the bottle.
If they sold them for $ as an add-on CD I'd be more than happy to buy them.
-Rick Greer, VAF #2492
Old 09-22-2010, 02:14 PM
Dave Taylor's Avatar
Dave Taylor Dave Taylor is offline
Default PM sent
Daniel,
I sent you a PM.
David
David Taylor
RV-7 N207DT
Wings
Warner Robins, GA
"The greatest mistake you can make in life is to be continually fearing you will make one. "
Elbert Hubbard
Old 09-22-2010, 02:48 PM
danielhv's Avatar
If they (Vans) sold them for $ as an add-on CD I'd be more than happy to buy them.
+1! It'd cost them to scan them, but after that, a few cents per CD (or even make them downloadable) would just be free revenue with no cost. In this day and age, where everything is going digital, its almost a must to offer something like that...
Old 09-23-2010, 05:53 AM
Bubblehead's Avatar
Originally Posted by Carl J. Niedermeyer View Post
No need to. With the latest version of the IOS, the latest version of the iBook app can handle PDFs.
I have iBook but do not know how to load a PDF in it. Carl - can you head me in the right direction?
