Originally Posted by Wayne Hadath
Kyle
I will check the vent lines. What do you mean by induction leaks?
Wayne
On a carbureted engine, you could have a leaking induction tube (cracked tube or loose clamp on the rubber hoses that connect the air intake and the induction tubes on the cylinder) or someone could have left a plug out of a port on a cylinder (maybe a primer port or manifold pressure port), leading to odd engine behavior.
A fuel injected engine could have the same plug/port issue, as could a throttle body type injector. I'm not sure what kind of induction leaks an engine with injectors on individual cylinders might have.
Good luck tracking this down.
