Old 09-19-2010, 08:41 AM
snoopyflys's Avatar
snoopyflys snoopyflys is offline
Default Another OAT Sensor Probe Question
I am researching OAT sensor probes. I am planning to install the probe in the VANs pitot tube hole (drilled on the wrong side of the aileron bell crank and have since gone with a pitot mast config) and need one that will fit the 3/8" hole. Are all OAT sensor probes created equal and compatible between manufactures?
Dan Schultz
=VAF= Annual Paid Subscriber
VAF #1446
Slow Building - 7A Tipper
Old 09-19-2010, 09:56 AM
Norman CYYJ Norman CYYJ is offline
If you can't find a probe to fit the hole take the one you have and remove it from its mount and remount it in a bored out bolt of the proper size.
Old 09-19-2010, 10:39 AM
Bavafa Bavafa is offline
No they are not. I have two, one that is from Garmin and one from GRT and thought they were interchangeable. So, I had connect them crossed and was getting all weird temps. Then I swapped the wires, Garmin to go with Garmin and GRT to GRT and both show good temps. Likewise a friend of mine bought his probe from Wal-Mart and he is getting Wal-Mart rated reliability/accuracy from the probe.
Mehrdad
N825SM RV7A - IO360M1B - SOLD
N825MS RV14A - IO390 - Flying
Dues paid
