Old 09-17-2010, 07:58 PM
Dave Taylor's Avatar
Dave Taylor Dave Taylor is offline
Default New slogan
Tonight while working on my second pass of the T-405 tank angle attach bracket I thought to myself "It doesn't have to be perfect, but it does need to be right". I've wasted alot of time on a stupid bracket that I hope will never be tested. But if it is, I believe it will work as Van intended it to.
David Taylor
RV-7 N207DT
Wings
Warner Robins, GA
"The greatest mistake you can make in life is to be continually fearing you will make one. "
Elbert Hubbard
Old 09-17-2010, 08:30 PM
snoopyflys's Avatar
snoopyflys snoopyflys is offline
Default I'll second that..
I had problems with z brackets on both tanks. Trashed 4 brackets before I got them right. I feel your pain. Enjoy the build.
Dan Schultz
=VAF= Annual Paid Subscriber
VAF #1446
Slow Building - 7A Tipper
Old 09-18-2010, 12:08 AM
tcone1's Avatar
tcone1 tcone1 is offline
My favorite saying..."perfect is the enemy of good"
Timothy Cone
Sierra Skypark (KE79) Fresno CA
RV-8, XP360, RV200
Flown Sept. 12, 2007
1600 hours on the hobbs and loving it
Old 09-18-2010, 05:17 PM
nauga nauga is offline
"It's better done than done better."
Nauga
2004 RV-4
Old 09-18-2010, 10:42 PM
Snowflake's Avatar
The Cult of Done Manifesto is worth including here too:
1. There are three states of being. Not knowing, action and completion.
2. Accept that everything is a draft. It helps to get it done.
3. There is no editing stage.
4. Pretending you know what you're doing is almost the same as knowing what you are doing, so just accept that you know what you're doing even if you don't and do it.
5. Banish procrastination. If you wait more than a week to get an idea done, abandon it.
6. The point of being done is not to finish but to get other things done.
7. Once you're done you can throw it away.
8. Laugh at perfection. It's boring and keeps you from being done.
9. People without dirty hands are wrong. Doing something makes you right.
10. Failure counts as done. So do mistakes.
11. Destruction is a variant of done.
12. If you have an idea and publish it on the internet, that counts as a ghost of done.
13. Done is the engine of more.
Rob Prior
