Old 09-16-2010, 03:33 PM
prkaye prkaye is offline
Default GTX 327 switching to ALT spontaneously
I've noticed that sometimes when I check my xpnder in flight, or at the end of a flight, it has switched itself over the "ALT" mode on its own (i select "STNDBY" for my local flights over my home airport). Is this normal?
Phil
RV9A (SB)
Flying since July 2010!
Ottawa, Canada
Old 09-16-2010, 03:39 PM
Lionclaw's Avatar
Lionclaw Lionclaw is offline
I believe the 327 will automatically switch to alt based on either NMEA data from a connected GPS or air data (pins 19 or 22 if I remember right?).
Maybe Stein or someone else here will know how to disable it...
Andy Compton, PhD EE
RV-10 - #41414 (building)
RV-9A - N643AC (built,flying,sold,missed)
My blood and sweat, the Wifey's tears
Old 09-16-2010, 03:43 PM
647jc's Avatar
647jc 647jc is offline
That's a configurable option, check your manual. It knows you have taken off by the change in the altitude provided it by the blind encoder output of the EFIS. The 327 can also switch back from ALT to Standby if you have it connected to a GPS and that option configured.
Joe Condon
Ankeny, Iowa
RV9A - 647JC - 300 hrs - SOLD 6/23/15
OneX - Under Construction - For Sale
