Old 09-15-2010, 07:45 PM
mtaviator mtaviator is offline
Default Garage Mods?
Hey all,
I'm finishing up a garage addition (28x32), that may serve as an RV factory in the not too distant future.
My question is- Is there anything you would install in the shop/garage specific to RV building?
I put in-
-dozens of outlets
-lights out the wazoo (6 four tube fixtures plus some task lights)
-220/20a for my table saw
-220/30a for a welder
-big workbench
-basin sink
What else while it's not too late?
Patrick Barrett
ATP, A&P, etc.
Old 09-15-2010, 08:08 PM
hydroguy2's Avatar
air compressor
either hose reels or multi air drops
Old 09-15-2010, 08:11 PM
Default Shelves and hangers
Shelves of different kind. Very useful to have couple shelves by the outlets for charging stations, storing stuff etc.
Old 09-15-2010, 08:12 PM
fstringham7a fstringham7a is offline
Default RE:Extras
heat and a/c ......
Frank @ 1L8 ...RV7A... Flying/Tracken (MT-RTG)
Oh yea, forgot to mention I have a good compressor. Although I might upgrade if I start building. I'm thinking of making an enclosure under the deck behind the garage to keep the noise outside.
Thanks.
Patrick Barrett
ATP, A&P, etc.
mattsmith mattsmith is offline
Default In the wall air
I put air lines in the wall with out lets about every 20 feet and under the front edge of the work bench that is permanently mounted to the wall. If I did it again I would put auto rewind reels for air and power in the ceiling.
Matt Smith
RV 8A
IO-360 A1A
65 Hrs
dual skiview
Reno, NV
Old 09-15-2010, 09:16 PM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
Bathroom..
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 09-15-2010, 09:29 PM
rv7boy's Avatar
rv7boy rv7boy is offline
Forum Peruser
Refrigerator...for keeping the ProSeal cold...as well as the beverages
Also, AM/FM radio, Air Scanner Radio, XM radio, Cable TV, Laptop PC with wireless to house, VHS or DVD player...for "From the Ground Up" and other videos...
My wife calls my shop the "Man Cave."
One more thing...a security system. I have two, but I can't go into detail here.
P.S. I have 9 foot ceilings, so on the walls I installed 4 by 8 OSB turned sideways (4 feet high). Then I installed 4 by 8 foot peg board from 4 feet to 8 feet (yes spacers behind pegboard to match thickness of OSB). Then I installed one foot of OSB at the top. All the OSB panels as well as the ceiling are painted white. Using OSB, I can screw or nail anywhere I want to. I have plenty of peg board space to hang stuff on near eye level. Works for me.
Don Hull
RV-7 Wings
KDCU Pryor Field
Pilots'n Paws Pilot
Old 09-16-2010, 07:15 AM
Wayne Gillispie Wayne Gillispie is offline
Default Exhaust fan/down draft table with hardware cloth for
painting, epoxy and mek fumes. Window or fresh air intake on opposite side of garage. Plenty of used 3 speed 115 volt furnace blower assemblies available from your local hvac guy. Install 20 x 25 air filter before blower. I also recommend hvac...keeps the sweat/humidity/corrosion off of your aluminum skins.
Good judgment comes from experience, and a lot of that comes from bad judgment.
Old 09-16-2010, 07:18 AM
N282S's Avatar
N282S N282S is offline
Default ceiling mounted retractable outlet
I put something like this in my shop and almost wore it out with use.
http://www.kaboodle.com/reviews/nort...-triple-outlet
Steve Stucky
Topeka, Ks
N282S - VariEze 500+ hrs
N283S - RV-7 1400+ hrs
KC-135 A/D/E Boomer (Ret.)
