Old 09-15-2010, 04:55 PM
TCONROY's Avatar
TCONROY TCONROY is offline
Default Grove Brake Reservoir
I see some builders have replaced the Van's brake reservoir with the Grove unit. Is there any good reason why I should do the same? I plan on getting the plastic hose replacement kit from Bonaco but am curious as to if there is some reason as to why I should replace the fluid reservoir? Any insight is appreciated!
________
Trevor Conroy CFII, MEI
Airbus Pilot
N781TD
RV-7
First Flight - April 12, 2015
Construction Log
Old 09-15-2010, 07:34 PM
roee roee is offline
Trevor,
There were several aspects about Van's reservoir installation that I didn't like, and so I redesigned it (using a Grove reservoir) to solve those problems. I did a write-up about it, problems and solutions:
http://www.kalinskyconsulting.com/rv...ereservoir.htm
Note that it's not flying yet, so no service history yet, use at your own risk, all the usual disclaimers...
-Roee
Roee Kalinsky
San Diego, CA, U.S.A.
RV-7A under construction
www.kalinskyconsulting.com/rvproj/
Old 09-15-2010, 09:45 PM
rocketbob's Avatar
Been flying for 10+ years with the stock setup, and haven't had to add a drop of brake fluid, ever.
Bob Japundza CFI A&PIA
N678X F1 Rocket, under const.
N8155F C150 flying
Not a thing I own is stock.
Old 09-16-2010, 01:03 AM
PCHunt PCHunt is offline
Default It's time.........
It's time to bleed the old fluid out, and replace with fresh. Hyd fluid absorbs moisture, and results in corrosion. Cheap insurance. I think every 5 years is good.
Pete Hunt, [San Diego] VAF #1069
RV-6, RV-6A, T-6G
ATP, CFII, A&P
2020 Donation+, Gladly Sent
