Old 09-15-2010, 09:26 AM
777drvr 777drvr is offline
Default Vacuum Pump Removal
Hi Guys,
I'm aware that when removing a vacuum pump that 3 nuts will be easy to remove with the 4th being difficult .
Do I need to order a special tool or can anyone offer a good tip to get it done without buying a tool I'll use once ?
Marc
1993 RV-4 C-GVMT
Formerly N144RS
SN 1444
Old 09-15-2010, 10:27 AM
vic syracuse vic syracuse is offline
Super Moderator
Yes, this tool makes it much easier...
http://www.aircraftspruce.com/catalo...nstalltool.php
but sometimes you can find a mechanic at the airport or an EAA chapter that has one that you can borrow.
Vic
Vic Syracuse
Built RV-4, RV-6, 2-RV-10's, RV-7A, RV-8, Prescott Pusher, Kitfox Model II, Kitfox Speedster, Kitfox 7 Super Sport, Just Superstol, DAR, A&P/IA, EAA Tech Counselor/Flight Advisor, CFII-ASMEL/ASES
Kitplanes "Unairworthy" monthly feature
EAA Sport Aviation "Checkpoints" column
EAA Homebuilt Council Chair/member EAA BOD
Author "Pre-Buy Guide for Amateur-Built Aircraft"
www.Baselegaviation.com
Old 09-15-2010, 01:57 PM
pierre smith's Avatar
Default Heat a cheap wrench cherry red.....
...and bend it to shape. Then use vice grips on the shank.
Best,
Pierre Smith
RV-10, 510 TT
Air Tractor 402 PT-6-20 Sold
Louisville, Ga
Patrick Kenny, EAA 275132
Dues gladly paid!
